Speedometer/Odometer Problem
Old Feb 10, 2007 | 09:04 PM
StrongRepublican's Avatar
StrongRepublican
I have an 88 F150 5.0L, and my speedometer only goes up to 85, so while I was driving on the highway today, doing about 100mph my speedometer completely rolled over to 0mph and then stopped working all together. It jumps around a little bit while I'm driving (needle jumps up to 50 pr so and then back down), but it certainly doesn't work. My odometer and cruuise control are also not working. I thought the wiring connection might have come loose under the hood, but it all looked fine when I checked. I also thought it could be a fuse, and I will check in the morning, but any advise would be helpful.
Old Feb 10, 2007 | 11:08 PM
grizz3000's Avatar
grizz3000
Does your year of truck have the speed sensor in the transfer case? Maybe you've stripped the gears on the speed sensor? My 89 250 sensor looked pretty cheaply made, all plastic gears. My 89 250 sensor slides into the transfer case, and the cable runs up to the engine. If that sensor went bad, it would also impact the cruise control I would think.
If your odometer doesn't work any more, I'd most certainly go find the speed sensor and pull it out to see if it's 'okay' and the cable end isn't damaged.
Just brainstorming here. Good luck.
Old Feb 11, 2007 | 01:14 AM
hillbilly delux's Avatar
hillbilly delux
probably the speed sensor gear in the tail shaft(assuming its a 2x4). Its little chincy *** plastic gear. The one on the end of the cable will be grey. If i remember correctly You'l have to get a new gear it from the FORD house. Check the new one against the old. when i did mine i had to do alittle modification to get the new gear to operate correctly. The problem should go away for a while, later you'll need to crack the tranny open and replace the spedo drive gear as well. had the same problem on my 88.
Old Feb 11, 2007 | 03:31 AM
grizz3000's Avatar
grizz3000
I got a whole new assembly at AutoZone for about $15.
Old Feb 11, 2007 | 08:33 PM
StillaKilla187's Avatar
StillaKilla187
it is a 4x4. so its at the transfercase? front or rear? oh this is strongrepublicans friend.
Old Feb 11, 2007 | 08:35 PM
StillaKilla187
not front or rear transfercase. lol. but front or rear of the transfercase?
Old Feb 15, 2007 | 01:04 AM
grizz3000's Avatar
grizz3000
mine was at the top of the TC, towards the front of the truck.
thegreatgate
33
Dec 2, 2021 07:59 AM
dfarland
Sep 23, 2010 03:06 PM
jonnyrocket_70
1983 - 2012 Ranger & B-Series
Aug 21, 2004 06:46 PM
hrsummers
Jul 9, 2003 08:38 AM
oldblue18
25
Dec 10, 2002 11:22 PM
