Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
poor engine function
Old Dec 30, 2008 | 03:27 PM
wptski's Avatar
wptski
Originally Posted by tonyford
Boy if that don't sound like a plugged up cat converter. That would be the first thing I would have checked out. A muffler shop could tell you if its plugged or not. What is baffling is the CHECK ENGINE light is not coming on, but then again the cat converter may be by passed.
The post CAT O2 would/should sense that.
Old Dec 30, 2008 | 05:17 PM
mikecarscallen's Avatar
mikecarscallen
Fixed 2003 Escape
Good troubleshooting! It was the cat converter- actually all three are plugged according to the exhaust shop. To find it I took the second O2 sensor in line out and it purred like a kitten. Of course reving it past 4K it started to bog down again, but that is to be expected. With the O2 sensor out the CEL finally came on! Thanks for your alls help. I will check the site from time to time to try to help someone else out. I'm actually not a bad mechanic, but this one had me baffled.
Old Dec 30, 2008 | 05:35 PM
tonyford's Avatar
tonyford
Someone else on this thread also mentioned the cat converter. Yup, the engine couldn't breath, it was choking on its own exhaust. Yes, the CEL came on not because of the plugged cat converter, but because it detected the O2 sensor not being there, lol. Not 100% positive, but I would bet that O2 sensor is bad also, because like Bill said, the O2 sensor should of picked up the plugged converter and light up you CEL. At least you found the problem, that's the main thing...
Old Dec 30, 2008 | 05:44 PM
bmuhlbach's Avatar
bmuhlbach
I'd check with the local Ford dealer emission stuff usually has a longer warranty then the 3 yrs -36000 miles.
Old Dec 30, 2008 | 05:50 PM
tonyford's Avatar
tonyford
Absolutely, if not mistaken, emission control parts and devices are warranted for 100,000 miles or 5 years. Definitely check on that..
67aj
Aug 29, 2014 02:23 PM
schuster66
Apr 22, 2012 10:57 PM
79_250RangerLariat
Feb 22, 2012 05:41 PM
Allie B
Aug 23, 2011 09:30 AM
dcexplorer
Aug 15, 2003 10:39 PM
