Help No Lights
Old Dec 5, 2016 | 06:02 PM
Talan's Avatar
Talan
Help No Lights
Just replaced the headlight switch and checked the fuse under the dash and still has the same issue. When turning on the headlights while pulling the **** the side markers or headlights won't come on at their position on the ****. However I can get either or to come on if I put the switch right between the both about 3/4 pulled out but not both at the same time. Everything was working before I replaced the headlights so I in unplugged them and the issue did not go away. Any ideas??
Old Dec 5, 2016 | 08:32 PM
ReBilld's Avatar
ReBilld
Was it doing the same thing before you replaced the switch?
Old Dec 6, 2016 | 10:54 AM
Talan's Avatar
Talan
Yes, replacing the switch didn't change anything. Could it be a bad harness? There was one wire loose but I pushed in back into the plug.
Old Dec 6, 2016 | 08:06 PM
ReBilld's Avatar
ReBilld
That's a strange one buddy. Check the big plug that goes on the back of the switch real well. Those things get really hot. Make sure it hasn't gotten hot and distorted the shape of it, like made bowed or twisted it a little. Make sure none of the wires coming out of that big plug have gotten hot and melted together. Also check all the grounds around the fenders and core support. I was having problems with my passenger side light and it was a loose ground.
stuckinthesnow
Electrical Systems/Wiring
Oct 26, 2023 09:22 PM
csonni
40
Jun 21, 2020 06:42 PM
manelady
Oct 27, 2008 02:17 PM
Snowman671
Mar 2, 2006 02:21 PM
RxWarrior
13
Oct 22, 2003 04:46 PM
