04 fog light issue
Old Mar 10, 2017 | 01:35 AM
Cory Barrow's Avatar
Cory Barrow
04 fog light issue
I've searched and searched I can't find anyone with the same problem.
2004 f250 lariat 4x4
Everything was working as it should and then I swapped out my header panel headlights and grill to 05-07 style. My headlights don't shine as bright on dim as they should but I'm getting 14v at the bulb.
Now to the fog lights when I use the dash switch to turn them on they will only turn on with the light switch on running light mode, meaning one turn to the right on the headlight switch. Now if I go 2 turns to the right the headlights come on as they should and the fog lights will stay on as they should however if I have to turn on my high beams at any point the fog lights go off as they are supposed to but do not turn back on after going back to low beam. I have to go through the entire process over by turning the head light switch back to running lights, turn fog lights off then back on and then back to regular headlight mode.
As far as the automatic headlight mode the headlights work as they should but the fog lights won't turn on at all.
Has anyone had this problem or heard of it?
Any help would be appreciated
Old Mar 10, 2017 | 11:26 AM
Yama4fitty's Avatar
Yama4fitty
Welcome to FTE and the 6.0 section.
Just for future reference when it comes to something not limited to the 6.0L diesel you might want to post in the Super Duty forum. You will get a broader range of people with the Super Duty that would not be limited to the 6.0 folks that mostly hang around here.
As far as your headlights, I have searched for some retrofits myself and noticed some complaints from people about the retrofits not throwing the light as well as the stock housing or some other housings. Or the pigtail was wired incorrectly or not making good contact whether a plug or a splice of some sort.
The fog lights sound like you might have a sticking fog lamp relay since that is the only thing that determines how the fog lamps operate when the high beams are activated.
Attached is the wiring diagram for your vehicle for the fog light system.
Good luck and again welcome
Old Mar 10, 2017 | 07:56 PM
BLADE35's Avatar
BLADE35
I did the fog light mod
it allows the fog lights to stay on regardless of high or low beam
FOG LIGHT MOD
S&S Diversified
Old Mar 11, 2017 | 09:18 AM
Leo Whitlock's Avatar
Leo Whitlock
Is there a mod that allows the low beams stay on with the high beams?
Old Mar 11, 2017 | 09:35 AM
Yama4fitty's Avatar
Yama4fitty
Thanks Blade35, you saved me to have to search for that. I've been meaning to do that mod forever now, but keep forgetting to until I want to turn them on while driving!
Leo, I do not know of one, but I'm sure someone has done it. I won't need to because with my LED light bar (replacing the fogs) and brights turned on together I'll be good to go. I do know if you do the momentary pull of the lever both the brights and regular lights stay on together. So I'm sure it can be done.
Old Mar 11, 2017 | 12:06 PM
Mike189677's Avatar
Mike189677
That's what the brite box does highs and lows and the same time.
Old Mar 12, 2017 | 10:36 AM
Leo Whitlock
Thanks for information on Brite Box, now ordered
Leo
Old Mar 12, 2017 | 10:52 AM
Iaff113's Avatar
Iaff113
Simple wire mod. Read through the thread to see what applies to you. Took me about 10 min.
https://www.ford-trucks.com/forums/9...htbox-mod.html
Old Mar 12, 2017 | 11:41 AM
TooManyToys.'s Avatar
TooManyToys.
The light functions change by model year but I made my own harness that keeps the lows on with the highs and a switch mod that keeps the fogs on with parking and highs.
Old Mar 12, 2017 | 09:25 PM
Cory Barrow
I did the s&s mod and here's what happened.
Head light fuse blows as soon as I turn the head lights on.
If I keep the fuse out and the turn signal switch on low beam the lights are on high beam and the fogs work great. If I push the turn signal switch forward like I was going to leave the high beams on I lose my headlights all together but the dogs stay on. Luckily for my situation my high beams aren't that bright and this actually worked out great but doesn't work as it should.
Old Mar 13, 2017 | 01:14 AM
Mike189677's Avatar
Mike189677
I'm not trying to be a jerk here but It sounds like you have some issues you need to get worked out before you did the fog light mod doing the fog light mod wasn't going to solve your original issue. What harnesses did you use for your 05 head light swap. With harnesses that are wired right everything should work as it did before did the lights work right before you changed to the 05 lights. Did you leave enough wire on on the fog light mod to reconnect it and are you sure you used the right wire to do the mod.
Old Mar 13, 2017 | 01:16 PM
Cory Barrow
I understand you're not being a jerk I appreciate your feedback
When I originally swapped out the headlights to the 05-07 style all I did was cut off the old connector and I picked up a new harness for 05-07 at oreilly's.
chazman
Jan 12, 2011 05:17 PM
Larry NCKS
2004 - 2008 F150
Jan 30, 2010 09:36 AM
TexasGuy001
General Automotive Discussion
25
Feb 3, 2006 02:48 AM
scarface78
Nov 12, 2005 09:12 AM
solidpwder
1997 - 2003 F150
Sep 22, 2004 04:34 AM
