manual trans id?
Old Feb 20, 2006 | 02:39 AM
ford390gashog's Avatar
ford390gashog
manual trans id?
i found a possible donor truck for the manual trans swap i want to do. but it seems to be a oddball. the truck is a 1976 reg cab f-150 with 360 and column shift. i have no clue what trans is in it. it appears to be side shifted and not top shifted like a NP 435. any ideas on what they used? it is it is the same length as the c-6 so i can use the driveshafts i have.
Old Feb 20, 2006 | 06:37 AM
docholiday72tx's Avatar
docholiday72tx
The only manual collum shifted trucks that there were, are 3 speed trucks. A 3 speed manual transmision does have the linkage on the side of the transmision.
Old Feb 20, 2006 | 11:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
What does the rating plate say? Try decoding it with the decoder.
Old Feb 20, 2006 | 02:20 PM
ford390gashog
the rating plate was gone. but it was a very small tranny so it probably was a 3 speed. any idea on the brand?
Old Feb 20, 2006 | 05:48 PM
thelaw's Avatar
thelaw
does it have 3 links on the side? If so this is what you have I believe. T170F (Code-RUG). It was used between the mid 60's to 79'.
78 & 87 Super Cab
1983 - 2012 Ranger & B-Series
May 7, 2014 12:53 PM
buckeyes8603
Apr 10, 2010 12:17 AM
vinnybean
Jan 15, 2007 04:31 PM
katdon2001
Mar 13, 2006 09:47 AM
conti98
Oct 11, 2004 06:09 PM
