manual trans shift points
Old Apr 13, 2014 | 08:47 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
What's the best recommended shift points, for My '01 Ranger? My main driving is in town, at no more than 35 mph. I have a 5 spd trans
Old Apr 13, 2014 | 09:20 PM
Conanski's Avatar
Conanski
When trying to get maximum fuel milage shift as early as possible perhaps never exceeding 2000rpm. What trying to get maximum acceleration shift at the RPM where the engine makes peak HP, that will be engine specific so you'll have to look it up.
Old Apr 14, 2014 | 07:50 AM
f5fordgirl's Avatar
f5fordgirl
Driving in town makes it hard to find the right points, works best just going by feel.
Old Apr 14, 2014 | 08:19 AM
KhanTyranitar's Avatar
KhanTyranitar
Yup, you go by feel. Lower RPMs is better, but you don't want to lug it.
Old Apr 14, 2014 | 05:56 PM
87 XLT's Avatar
87 XLT
Your owners manual will tell you.
Heres what the owners manual for my 87 2.9 tells me.
Upshifts normal acceleration:
1-2 9 MPH
2-3 22 MPH
3-4 34 MPH
4-5 45 MPH
Upshifts ford best fuel economy:
1-2 10 MPh
2-3 19 MPH
3-4 30 MPH
4-5 43 MPH
You can also skip gears if you want,. Example when i'm getting on the freeway I take it up to 70 MPH in 3rd & shift from 3rd to 5th. Might waste a little fuel, but it's a lot more fun.
Old Apr 14, 2014 | 09:53 PM
wtroger's Avatar
wtroger
+1 on what khantyranitar said
Old Apr 15, 2014 | 08:30 AM
78 & 87 Super Cab
I've been trying shifting 1-2 at 15, 2-3 at between 20-25. I hardly ever go into 4th in town unless I'm going over 35-40
Old Apr 15, 2014 | 10:28 AM
Old93junk's Avatar
Old93junk
There used to be small marks on the speedometer indicating shift points at certain mph's but I don't know if newer Rangers still have them.
Old Apr 15, 2014 | 02:12 PM
smalltrucker's Avatar
smalltrucker
I've always gone by feel, numbers on a spedo mean nothing because of the different rear gears. That has gone for all the different cars/motors I have had.
Dave
Old Apr 16, 2014 | 08:07 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Abilene KS is pretty flat. Even the 4 cyl can pull these things around easily in 4th @ 30-35 MPH on fairly flat terrain. Hills are a bit different.
Old May 3, 2014 | 07:09 PM
Bright Regatte Blue's Avatar
Bright Regatte Blue
That sounds about right for a Ranger. My F-150, on the other hand, has a 5.0L and 3.55:1 gears...I shift that thing into fourth at 25 MPH!
Old May 7, 2014 | 12:53 PM
BarnieTrk's Avatar
BarnieTrk
That sounds about right.
I very rarely ever shift at less than 2000 rpms, maybe if I was to start out going downhill - but then I have a 4-cylinder. I usually shift by the tach reading in the range of 2000 - 2300 rpms.
Realize that a tachometer is a more important guide tool when determining shift points than a speedometer. Speed versus RPMs will differ with different-sized tires and different rear end ratios. Of course if you're going uphill or downhill will also effect the work load / lug on your engine.
In my opinion, it's less wear on the engine if you rev the engine up some rather than lugging the engine down. This is more important to do with the smaller engines - bigger engines (like a V8) can be lugged down (1500rpms) with less chance of hurting it.
BarnieTrk
Ridge
Nov 18, 2015 09:53 AM
LeoJr
May 3, 2012 09:16 PM
Ian123
Jul 8, 2011 09:15 PM
Mud-and-Guts
Jan 3, 2010 06:15 PM
Crazyromi
1978 - 1996 Big Bronco
Oct 13, 2003 12:49 PM
