now i have a 77.5 f-250 crewcab 4x4 that im restoring i want to put a 6 inch skyjacker lift with 38/11 r16.5 super swamper tsl raidals with a dana 44 and dana 60 with 4.10 gearing planing to put limated slip diffs in one day when i have enough cash also when lifting what all do u need to do to the sway bars when lifting a truck to keep them they are factory ones? also swap in a mildely built 460 with fenderwell exit headers also a 4 speed trans. how would all of this work togeather will i have any problems or do any of you have any sugestions?
Everything you mentioned sounds like it should work together with out a problem.
The only thing you would need to do, to keep the sway bars would be to lengthen the drop links that go from the frames to the sway bar itself.
A 77.5 F-250 should be able to clear 38s with less than a 6" lift, someone else might be able to confirm this, but if not, ask that question in the offroad forum.
