Coolant Filter Installation
Old Feb 19, 2006 | 07:57 PM
xlrs's Avatar
xlrs
Hello All,
Does anyone have instructions and part list for a coolant filter install.
Newby to the 6.9. Truck is an 87 F250 6.9 4x4. Any help would be greatly appreciated.
Thanks
XLRS
Old Feb 20, 2006 | 05:28 AM
PLC7.3's Avatar
PLC7.3
The whole kit is available, however installation on the older trucks is usually not covered in installation...... so it would be do it yourself.
http://www.dieselsitetoo.com/index.a...ROD&ProdID=443
Old Feb 20, 2006 | 04:34 PM
dieself250's Avatar
dieself250
Red are supply hoses and blue are return
NAPA 4019 filter base
NAPA 4070 coolant filter
2 Brass T's
a few hose clamps
5/8 heater hose
Plumbed in parallel between the heater hoses
total cost under 100.00
Old Feb 20, 2006 | 05:33 PM
xlrs's Avatar
xlrs
dieself250,
Thanks a million. That is exactly what I was looking for! Thanks to all who replied.
XLRS
Old Feb 20, 2006 | 07:07 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If you use the 4071, I think that's the right number, filter it's precharged with SCA's. That's assuming the IDI's require the same SCA's the newer trucks use.
Old Feb 20, 2006 | 07:19 PM
dieself250's Avatar
dieself250
Using a precharged is a good idea, at first i would use a plain filter and plain on changing it every month for a bit.it took about a month for mine to gunk up, easy way to tell if its gunked up is after the truck is hot the filter will remain cold
EightySecond
Oct 27, 2019 12:52 PM
maxride
74
Jan 31, 2016 07:43 PM
Superduty450
6.7L Power Stroke Diesel
Oct 11, 2015 06:21 PM
maxride
Mar 28, 2015 04:15 PM
morimoto_87
19
Aug 11, 2010 09:46 PM
