Baldwin Filters???
Old Aug 8, 2010 | 10:11 PM
morimoto_87's Avatar
morimoto_87
Baldwin Filters???
What do you guys know about BALDWIN Filters?? Theres a guy here in Omaha selling 4 baldwin fuel filters for a 83-87 6.9 for $12 and 6 Baldwin air filters for $25. Second off will the 6.9 Fuel filters fit my 7.3?? Thanks Guys!
Old Aug 9, 2010 | 02:05 AM
oreocreaming's Avatar
oreocreaming
great filters, thats all we use at work. and ya, 6.9 filters are the same as 7.3
Old Aug 9, 2010 | 10:06 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
No 6.9 Fuel Filters are not the same as 7.3 filters ...
6.9 Filters have 7/8-14 threads.
7.3 Filters have 1-14 threads.
Baldwin's are ok.
-Enjoy
fh : )_~
Old Aug 9, 2010 | 10:32 AM
oreocreaming
really? the filter book shows same. 87 6.9 different then pre?
Old Aug 9, 2010 | 11:11 AM
Festus Hagen
Methanoholic
Yes, Really!
I'll state it this way ...
If you have a 7.3 style fuel filter head, the center hole size is 1" using 14 TPI.
If you have a 6.9 style fuel filter head, the center hole size is 7/8" using 14 TPI.
-Enjoy
fh : )_~
Old Aug 9, 2010 | 11:20 AM
morimoto_87
Ok, looks like i'll get the air filters then and leave the fuel filters behind...great deal though, the air filters have the foam liner on the outside which i've never used so i'll give them a shot! They can't be that bad seeing as how i have a fram in there now and can almost see through the filter so the foam must have to catch more dust and junk. Thanks for the input guys! FTE KICKS @$$!!
Old Aug 9, 2010 | 11:25 AM
oreocreaming
someone changed my oil cooler on my 6.9l cause it's the same as my 90
Old Aug 9, 2010 | 01:45 PM
greywynd's Avatar
greywynd
Oreo, they are fuel filters, not oil filters. Oil filters are the same on all the IDI's, the fuel filters changed though. I suspect it changed with the water separator,which wasn't actually at the same time as the change from 6.9 to 7.3 if I recall correctly from another thread. The earlier 6.9's were a straight filter with the water being a different unit on the firewall. Later (mostly 7.3's) when the separator was eliminated, it then became a water separator/filter in one unit.
Old Aug 9, 2010 | 02:27 PM
oreocreaming
ah, didn't notice the op saying fuel
Old Aug 9, 2010 | 10:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
86 and older truck, water seperator on the firewall, small filter nipple for the fuel filter.
87 6.9 and all of the 7.3 had the new style water seperator/fuel filter combo, no seperator on the firewall.
Old Aug 9, 2010 | 10:24 PM
poocher pup's Avatar
poocher pup
my '87 6.9l had the water seporater on the firewall.
Old Aug 10, 2010 | 09:22 AM
ford390gashog's Avatar
ford390gashog
I get all my filters very cheap. I never pay more than 9.50 for the fuel filter on my truck. Most of the time I use wix or luberfiner filters. Check out Discount oil filters H&S Industries - Lodi, WI
Old Aug 10, 2010 | 12:51 PM
elinmon1976's Avatar
elinmon1976
If the sidewall water seporator has been removed, do you have to get the filter with the seporator?
Old Aug 10, 2010 | 04:57 PM
Hamberger's Avatar
Hamberger
Baldwin Filters
I have used a few Baldwin filters over the years. Only use Baldwin for my coolant treatment on my 93' F250 these days. They work great.
I use the extra large 2 micron Racor Filters R60S for fuel filtration (you will need to change the filter bracket to do this)
I also have been buying the extra long oil filters (FRAM PH-3786 instead of PH-3766, sorry Dave S., I know how much you loath those FRAM Filters) I figure for the two extra bucks why not go for the oil fiters they use on the Powerstroke Diesels, less pressure drop, more flow, more filtering areas.
Regards,
Seb....
Old Aug 10, 2010 | 07:04 PM
morimoto_87
excellant information guys, i was wondering though...i've tried to use the powerstroke oil filter (valvoline) on my truck once and the threads and hole was completely different, so is there something i've got to change out before i can run the powerstroke filters?
