Remove turbo to install ATS?
Old Feb 19, 2006 | 05:35 AM
ru1234's Avatar
ru1234
Do you have to completely remove the turbo to install the ATS housing?
Old Feb 19, 2006 | 06:10 AM
PSNut's Avatar
PSNut
Welcome to FTE ru1234!
No u don't have to remove the turbo for the ATS housing. I believe having a swivel joint helps on a few tight corners.
Nut
Old Feb 19, 2006 | 07:16 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
check johnny8's gallery, he has great instructions on how to change the compressor wheel (same theory, just don't remove the wheel) without removing the turbo from the pedestal.
Old Feb 19, 2006 | 07:28 AM
HeatStroked's Avatar
HeatStroked
No, stock housing has 5-6, 5/16, 12 point bolts. Disconnect your waste gate and don't lose the clip. I recommend getting a spare before you start. You will drop it.
Rremove your intake boots and remove the stock housing bolts.
There is one difficult bolt to get too. Make sure you have a 1/4" swivel, short extension and a spare deep 5/16" 12 point socket. You can easily split the thin wall socket trying to get that one bolt out!
Old Feb 19, 2006 | 07:54 AM
PowerstrokeJunkie
i would also like to mention that an 8mm 12pt socket will suffice. i went to several hardware stores and only could find the 8mm, no 5/16''. i calculated it out, and there is only a few thousandths difference. i have used it several times on turbo bolts and it doesnt slip or twist off the heads.
just did the math:
5/16''= .3125''
8mm= .3149'' (1''=25.4mm)
Old Feb 19, 2006 | 07:57 AM
HeatStroked
Sears has the Craftsman 5/16" 12 point deep sockets.
Strokin is correct, they are difficult to find.
Old Feb 19, 2006 | 08:29 AM
ru1234's Avatar
ru1234
Thank guys. It doesn't sound or look all that tough. I think I'll give it a shot. I've got a 2000 PSD so I don't think I'll need to change the wheel over to a WW. If you have any more suggestions I'd love to hear them.
Thanks again.
Old Feb 19, 2006 | 08:31 AM
PSNut's Avatar
PSNut
Thanks again.
Your correct about the not needing the WW with the ATS housing.
Nut
Bluecrew250
Aug 1, 2011 07:06 AM
16Vjohn
Oct 19, 2010 07:17 PM
pontichev
Apr 7, 2009 01:51 AM
wb6anp
Feb 26, 2008 11:49 PM
Brats
Dec 21, 2006 05:03 AM
