Aerostar Ford Aerostar
Engine still missing
Old Feb 20, 2006 | 09:12 PM
cjfaber's Avatar
cjfaber
just talked to a guy who read the codes for me and thinks that its the coolant sensor. He pulled the plugs and they were all carboned up, he cleaned em and it ran good for a little bit, then they just carboned up again. I will prolly install a new engine coolant sensor and see what that gives me
Old Feb 22, 2006 | 10:45 AM
cjfaber's Avatar
cjfaber
I got the areostar back today. The guy who read my codes from a local repair shop told me that it could either be a coolant sensor which he thinks is unlikely or a fuel pressure problem. The thing is they took the fuel pressure there and it was at 80 PSI which is double that it should be. We are thinking somethign is going wrong with the whole fuel pressure regulator. Maybe a vacuum leak of some sort. Anyone got any further input?
Old Feb 22, 2006 | 11:11 AM
VanGo's Avatar
VanGo
Check this article out. here's a piece "With the return line pinched shut, the pump should produce two times its normal operating pressure at idle."
Fuel Injection Problems
Old Feb 23, 2006 | 11:42 AM
Bear River's Avatar
Bear River
Former ******
Yes, this is true, the native pressure of the pump is 60-80 psi. If the return line is blocked or pinched, the pressure cannot be regulated down to an acceptable level, and excessive fuel will escape through the injectors.
87f250banks
1983 - 2012 Ranger & B-Series
19
Apr 2, 2011 10:03 AM
5.4L to Freedom
May 18, 2010 09:50 AM
bobgti86
Sep 5, 2009 08:42 PM
cjfaber
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 18, 2006 09:56 PM
txmoores
Oct 21, 2003 05:26 PM
