Intermittent Engine Miss @ Idle, No Error Codes
Old Oct 19, 2003 | 07:42 PM
txmoores's Avatar
txmoores
Angry Intermittent Engine Miss @ Idle, No Error Codes
I have a ’96 Bronco with a 351W which has a miss at idle. The engine will be idling smooth for around 5 to 10 seconds and then miss and return to smooth idle for another 5 to 10 seconds. This only occurs at idle and runs smooth all of the rest of the time and throttle position. I have changed the fuel filter, plugs, wires, cap, rotor, coil and air filter. I took it to a local shop and they put it on their computer and there were no error codes, although the front most O2 sensor was a little on the lean side, but within limits. Anyone have any ideas?
Old Oct 21, 2003 | 11:58 AM
circledirt's Avatar
circledirt
Misses only for an instance? In an effort to maximize fuel economy a lot of ECM,s run the engine as lean as possible while idling. Lean to the point of occasional misfire. If lite not coming on in dash, runs ok the rest of the time, and never dies at idle I wouldnt worry about it.
Old Oct 21, 2003 | 04:02 PM
pfogle's Avatar
pfogle
how many miles are on this engine? My 351HD does this, and it's got ~150k. It is probably just a normal thing.
Old Oct 21, 2003 | 04:10 PM
txmoores's Avatar
txmoores
Thanks all for the responses. The Bronco is actually for my soon to be 16 year old son (one helluva lot better than the '59 F100 I had saved up my lawn mowing money for when I was 16!!) and has 60,500 miles. If you put it in neutral and rev it up and hold it at 1,000 rpm the infrequent miss goes away. Can one of those Supertuners (or something like it...) be used to alleviate this and to also help out performance a little? Can the ECM be tricked some way? Would larger throttle bodies be any help?
Old Oct 21, 2003 | 05:26 PM
pfogle's Avatar
pfogle
Fuel filter is a possiblity too.
tr0y
Nov 10, 2014 07:02 AM
Skyhawk Greg
73
Sep 15, 2014 10:29 AM
Shernius
1997 - 2003 F150
Oct 27, 2013 06:02 PM
fordtruck88
30
Feb 16, 2006 11:05 PM
txmoores
1978 - 1996 Big Bronco
Oct 22, 2003 09:37 AM
