Autometer Guages???
Old Feb 16, 2006 | 12:10 AM
CLStewart144's Avatar
CLStewart144
Question Autometer Guages???
Just wondering.. Black Cloud sells a kit with pillar and autometer guages for $279, but I haven't heard or read much about the autometer guages on here.. Are they no good, or just as good as the rest?
Also, if they are good, what kind of extra stuff am i going to need to hook them up??
Thanks
Chris
Old Feb 16, 2006 | 12:21 AM
DavidT.'s Avatar
DavidT.
Autometer are among some of the best gauges avaliable...even NASCAR uses them. BCDP has the 3 gauge package for $300...you get the wiring kit, pillar painted to match your interior and free shipping. Instead of $279 and having to add all that extra, comes out to way more than $300.
Old Feb 16, 2006 | 12:34 AM
DieselFuelOnly's Avatar
DieselFuelOnly
Autometer is pretty much the best stuff around in my opinion. They have a nice webpage, you should check that out if you doubt me.
The kit from black cloud should come with everything you need to hook it up minus a way to splice in the boost guage and wire the guages. All you need for that is a 3/8 NPT Tee fitting and two 1/4" hose barbs with 3/8 NPT pipe thread. You splice that into the MAP pressure line and you're done. Pretty simple.
The hardest part is hooking up the wiring and finding the right wire for illumination. I forget the color of the wire (somebody else will fill it in soon, i'm sure) but you can tap into the illumination wire that is behind your dimmer control. You'll need an ingition wire too. I found a spare unused wire behind the dash by the radio that was hooked up to the ignition. I have an "ignition accessory" relay I installed this wire to. This way I don't draw much power from this random extra wire. It simply triggers the relay when the key is on. Other then that, all you need is a ground wire, but that could go just about anywhere.
Pretty simple evolution, just takes some time to run the wires if you want to make it look good. I already had a hole in my firewall too, so it was easy to run the boost line. You'd probably have to drill one if you haven't already.
Old Feb 16, 2006 | 12:40 AM
jtharvey's Avatar
jtharvey
You might check Black Cloud Diesel Performance, instead of BCD. Garrett is now a sponsor!! Here's the link: http://www.blackclouddieselperforman...alog/index.php You might need to call him though, as his webpage is still under construction.
Autometer's are great. I like mine. Clear and easy to read.
I think the wire behind the dimmer panel is orange for the illumination. Use a volt meter or test light to be sure.
Old Feb 16, 2006 | 12:47 AM
jtharvey's Avatar
jtharvey
Here's a link to the BCDP pre-assembled and color matched guage pods.
http://www.blackclouddieselperforman...roducts_id=144
Old Feb 16, 2006 | 01:16 AM
DavidT.'s Avatar
DavidT.
[QUOTE=jtharvey]Here's a link to the BCDP pre-assembled and color matched guage pods.
http://www.blackclouddieselperformance.com/catalog/product_info.php?products_id=144[/QUOTE]
Yeah, I meant BCDP not BCD. My bad. Garrett ROCKS!! Infact, I just ordered a set for myself so I can give my dads gauges back to him lol (He only uses his truck during the summer). I got the $300 package w/the Phantom gauges.
Old Feb 16, 2006 | 01:21 AM
jtharvey's Avatar
jtharvey
Originally Posted by DavidT.
Yeah, I meant BCDP not BCD. My bad. Garrett ROCKS!! Infact, I just ordered a set for myself so I can give my dads gauges back to him lol.
I agree!! Garrett is great to do business with. And, I'm all for supporting our sponsors. They help make this site possible, so I like to give back to them when I can.
Old Feb 16, 2006 | 01:52 AM
rclark1's Avatar
rclark1
Thumbs up
I have the Autometer Phantoms with a triple pod and could not be happier with them, Work and look great.
Old Feb 16, 2006 | 07:34 AM
generalee31184's Avatar
generalee31184
2 gauge assembled A pillar or other
Why am I having trouble finding a 2 gauge pod? as I have a manual so dont need the tranny temp. Any suggestions?
Old Feb 16, 2006 | 08:03 AM
cangim's Avatar
cangim
Check out egauges.com, they have all sorts of mounting options.
I also have autometer Phantoms, couldn't be happier, I even change the gauge face out on the main cluster to match the Phantoms.
Old Feb 16, 2006 | 09:29 AM
jtharvey's Avatar
jtharvey
You should be able to track one down pretty easy. Call Garett at BCDP, I'd say he can set you up.
Old Feb 16, 2006 | 09:36 AM
blueeyes2478's Avatar
blueeyes2478
I have the autometer C2 gauges and i couldnt be happier.They work great,just the the blue light was to bright,even tied into the factort dimmer.So i had to dimme them independently.Besides that there great.
Old Feb 16, 2006 | 10:49 AM
fei1's Avatar
fei1
I ordered my three guage pillar and choice of autometer guages from www.motoblue.com. I chose the ultralite series and couldn't be happier. They also have the two guage pillar.
Old Feb 16, 2006 | 03:28 PM
crzybowhntr's Avatar
crzybowhntr
Try RPMoutlet.com I got my phantom series EGT and Boost plus 2 gauge pod shipped for 210.00
Old Feb 16, 2006 | 05:33 PM
1984_355w's Avatar
1984_355w
We've got Autometer Sport-Comps in our one ton. Love um, got the whole set-up from Summit and they're made in Illinois just like me!
