Need Help
Old Feb 15, 2006 | 11:52 AM
BEARMAX's Avatar
BEARMAX
Need Help
I Have A 72 Sport Custom The Front Brake's Are Locking Up
I Have Replaced The Entire Brake System But The Prop Valve And That's Is Becouse I Cant Find One .so This Has To Be The Prob .anyone Every Had This Prob.
Old Feb 15, 2006 | 08:47 PM
charles jones's Avatar
charles jones
Bearmax, I had my power booster rebuilt and put a new master cylinder on it. The rod between my power booster and new master cylinder was to long and caused the brakes to be on all the time. I had to shorten that rod to make the brakes release. I have a prop valve but I have never put it on. They work so good with out it. I got the porp valve off a 73 F250 donor truck I have. I would think you could find one in a wrecking yard. Hope this helps
Old Feb 15, 2006 | 08:57 PM
BEARMAX's Avatar
BEARMAX
i did replace both of them i wonder if thats the prob how much did you cut off the rod .and how long is it now ....thank you for the info i will def look at that
Old Feb 16, 2006 | 06:57 AM
charles jones
Bearmax, I had to cut a total length of about 1/8in. Mine had a 1/4in adjuster on the end that I shortened as far as it would go. Then I had to cut the rod 1/8. I put a scew back in the threaded rod and ground it into a ball type end to match the ball end that I unscrewed. I loosened the master cylinder from the power booster 1/8in at a time to see when they released. That gave me a rough idea of how much to long it was. I had to put it on and off about 6 times to get it right. Good luck and let us know how it comes out. Charles
Old Feb 16, 2006 | 09:31 PM
BEARMAX's Avatar
BEARMAX
Charles You Are Awsome Bro Thismorning Before I Went To Work I Loosend My Master Cylynder Enough To Alow It To Move With The Braks Pressed I Drove To Work With No Prob And Noticed A Drastic Change It Gas Milage And Performance..the Best Part Is I Didnt Smell My Pads Burning On The Way .at Lunch I Pulled The Master And Found The Rod To Be Adjustible So I Drove It All The Way In And Wala No More Locked Brakes .and To Think Iv'e Been Driving It This Way For About A Year And Replaced Every Part Of The Brake System And It Only Took Me 3 Min To Fix It ...thanks A Lot Charles ...
Old Feb 17, 2006 | 07:03 AM
charles jones
Bearmax, Thats great. I,m glad it worked out for you so good. I know I was relieved when I figured mine out with some help from all the guys here at FTE. Good luck Charles
Bryishre
Oct 11, 2011 11:55 AM
devilmade
Mar 8, 2010 01:50 PM
noggins71
Jun 11, 2009 09:11 AM
superman64011
Sep 5, 2004 12:31 AM
Mac 25
Nov 26, 2003 06:23 PM
