Brake light prob
Old Jun 10, 2009 | 06:42 AM
noggins71's Avatar
noggins71
Brake light prob
I have just replaced the in cab wiring harness on my 1993 F-150. The problem is that the fuse for the brake lights/turn signals is popping when I put the brake on. If I disconnect the switch for the brake lights the fuse does not pop. Does this sound like a bad switch or a ground problem?
Old Jun 10, 2009 | 07:01 AM
Lazy K's Avatar
Lazy K
If you pull the plug at the brake light switch, one wire will have 12v at it and the other goes to the brake lights and the RABS computer. I bet if you remove the brake light bulbs and ohm that wire you have a direct short to ground. I am no expert but I think that wire goes up the steering column to the turn signal switch before going to the brake lights, it also goes to the RABS computer. My guess would be you have a short in the steering column wiring.
Old Jun 10, 2009 | 09:23 AM
noggins71's Avatar
noggins71
reply
Thanks for the info Lazy K, I will read that out today
Old Jun 11, 2009 | 09:11 AM
noggins71's Avatar
noggins71
I took everything off of the column, egn switch,turn sig switch and the eng module under the column. checked all wires and re-installed everything, now the fuse will blow as soon as I hook the brake switch up. I do not even need to push the brake pedal.
TSmylie
Sep 14, 2014 03:45 PM
slfrey67
Escape & Escape Hybrid
Aug 28, 2013 08:19 PM
slowjet
Oct 6, 2010 12:31 PM
TRX450R
Jun 29, 2007 12:51 PM
nightshifter
Aerostar
Mar 2, 2006 12:34 AM
