4 speed tranny
Old Feb 15, 2006 | 11:38 AM
cowboy dan's Avatar
cowboy dan
4 speed tranny
the 4 speed for the diesel is the t-19, doese anyone know if the bellhousing off the t-19 will fit on the t-18 gas version also did these come from the factory with a trans adaptor, ive seen these on e-bay and dont know what it is. and what is the benefit of a dual mass flywheel.. thanks for any help
Old Feb 15, 2006 | 09:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The dual mass has no advantages.
Many people that have them are paying good money to swap to a solid flywheel so they can get rid of the dual mass.
Tranny should bolt to the bell housing.
Bell housing from a gasser motor will not bolt to a diesel motor or the other way either.
What everyone is calling an adapter is a spacer on the back of the motor that bolts to the motor and the bell housing then bolts to the spacer. The starter also bolts to the spacer. I am going to go find an International truck with a 7.3 in it just to see if they also use the same spacer.
I think they do unless the starter bolts to the International bell housing.
Old Feb 16, 2006 | 07:01 AM
cowboy dan's Avatar
cowboy dan
hey dave thanks for your help. does the c-6 use the spacer also or just the manual, and will they interchange
Old Feb 16, 2006 | 09:07 PM
Dave Sponaugle
The transmission when talking about the C6, A4OD, ZF5 and ZF6 all have integral bell housings and bolt directly to the spacer.
Spacer bolts to the back of the motor.
Dr. Dirt
31
Nov 17, 2021 09:35 PM
bill11012
Jun 16, 2009 09:25 PM
bill11012
Jun 14, 2009 10:54 PM
unobvs
Jun 19, 2007 06:30 PM
86diesel-
Mar 23, 2006 07:07 PM
