Unwanted Shut Off
Old Feb 15, 2006 | 09:25 AM
RONZZONI's Avatar
RONZZONI
Unwanted Shut Off
Have Had A Problem With 7.3 Shut Off At Times And Have Heard That The Cam Position Sensor Could Be At Fault? Have Allready Replaced The Crank Sensor But Still Happens. Had A Bd Chip Installed And After Removing Have Had No Problems. Could It Be The Chip Had Worked Loose And The Cam Sensor Going Bad? Where Is The Cam Sensor Located? Please Advise
Zoni
Old Feb 15, 2006 | 09:37 AM
guzzle92's Avatar
guzzle92
Not sure what you are meaning with a 'Crank Sensor' other than you are actually referring to the CPS. If you have removed the chip and the problems went away, that was most likely your problem. It could be that whoever installed the chip did not do a good enough job on cleaning the PCM contacts and you were not getting good contact on one or more of the connections. It is possible that the chip has gone bad but unlikely. If you have already changed the CPS, I would try and clean the PCM contacts up and re-install the chip and see if your problem reappears.
The CPS is located on the front of the engine at about the 10:30 position on the dampner. It's held in with a 10mm bolt. You have to get to it from below the engine.
Old Feb 15, 2006 | 09:40 AM
zx250's Avatar
zx250
Of the next Riffraff East
Have you pulled any codes yet? If it is a CPS it should show a code. If not I would suspect that your chip is loose or could be dirt or corrosion on the contacts on the chip.
Old Feb 15, 2006 | 09:44 AM
guzzle92's Avatar
guzzle92
Pulling codes anytime you have a problem is a very good idea and wise thing to do but unfortunately, most of the time a CPS failure will not throw a code.
Old Feb 15, 2006 | 09:55 AM
RONZZONI's Avatar
RONZZONI
Thanks For Feedback; Crank Sensor Is The Crank Position Sensor Parrelel To The Harmonic Balancer On The Left. The Shut Started Occuring At The 76859 Mile Range, Chip Installed At 14000 Miles. No Codes Appeared On The Odb Scan,removed The Chip And Have 7000 Miles With No Major Problem. Have Had Idle Drop Several Times While In Cruse Control But Never Shut Off.will Install Chip Myself And Verify Problem Resolved Or If It Reoccures. Thanks Zoni
Old Feb 15, 2006 | 10:12 AM
zx250's Avatar
zx250
My bad, Mine threw a P0344 when it went out.
Old Feb 15, 2006 | 12:32 PM
doubleu1964's Avatar
doubleu1964
Same problem
Looks like I have the same issue right now. Does yours shut off once it gets warm? How long before you can restart it?
The Chip was taken out of this one a few month ago.
buddy
Old Feb 15, 2006 | 04:12 PM
RONZZONI's Avatar
RONZZONI
It First Started Slow About Every 7-8k Miles Would Just Quit While In Cruse Control At 70-80 Mph. Questioned Whata-up/went Straight Toford And No Codes/it Started To Happen More Often And Sometimes Would Happen When Backing Out Of A Spot/shut Off Then Have To Restart//cycle The Key. Was Told(dont Know If True) But If It Quits And You Recycle The Key And It Starts Then You Might Have Errased The Code?then One Morning Went To Start And Nothing/followed Instructions In Owners Book And Still Nothing//had To Have It Towed To Ford For Them To Reprogram Something(think It Had To Do With Security Lockout)but Dont Know. Then It Started To Go Bad And Not Start Or Shutoff Every 773.6 Miles///back To Ford And No Code Replaced Crank Position Sensor Still Happened Every 773.3 Miles//back To Ford ///no Codes But This Time They Asked If I Had A Chip--of Course I Did So I Removed It(they Wanted 275.00 To Remove) Drovew Around The Block,cked Codes//no Codes. Have Driven Total Of 9686.2 Miles No Problems. Will Reinstall Chip And See If It Had Worked Loose.
Zoni
Old Feb 15, 2006 | 04:16 PM
RONZZONI's Avatar
RONZZONI
Milage Sucks Without Chip
Zoni
Old Feb 15, 2006 | 04:29 PM
WuShock's Avatar
WuShock
As Old Fart suggested. Clean the contacts on the PCM again 99% of the time that will be your problem. What kind of chip do you have?
Old Feb 15, 2006 | 04:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
LMAO!!!
Old Feb 15, 2006 | 04:40 PM
guzzle92's Avatar
guzzle92
Originally Posted by strokin_it7.3
LMAO!!!
You should be, you adolesent green haired punk kid! (just kidding)
Old Feb 15, 2006 | 05:03 PM
WuShock's Avatar
WuShock
Hey wear that title proudly. All of us should be so lucky as to make it to Old Fart status someday.
seanj5202
30
Jan 12, 2016 09:54 AM
ldwzlaw
Dec 6, 2012 05:36 AM
bigdawg460
Feb 17, 2008 12:00 PM
vtcart
Sep 24, 2004 06:26 PM
effiman
1997 - 2003 F150
Oct 11, 2001 10:01 PM
