Starter?
Old Feb 13, 2006 | 09:55 PM
sixshootingexp's Avatar
sixshootingexp
Starter?
I have a 79, f-150, 2 w/drive, 300ci, automatic, with 110,000 miles.
10,000 miles ago I put a new flyheel, and starter in.
Today it wouldnt start, it just does the, one click.
I tried to turn the motor manually with a 15/16 socket on the crank shaft pully, but it wouldnt budge.
I guess my question is, should I be able to turn the motor with a rachet on the crank shaft pully?
Old Feb 13, 2006 | 10:24 PM
fyrrmann's Avatar
fyrrmann
You should be able to turn it on the crank pulley will just be a little tough w/ compression. Sounds like something may be binding on the inside or at flywheel.
Old Feb 13, 2006 | 10:53 PM
Bdox's Avatar
Bdox
Pull the plugs and try it again. Nine times out of ten a 'no start' is electrical.
Old Feb 14, 2006 | 09:55 AM
sixshootingexp
Thanks for the response. I am on my way.
I'll let you know.
Old Feb 14, 2006 | 11:07 AM
Mil1ion's Avatar
Mil1ion
Automatic Transmissions use Flexplates.
Standard Transmissions use Flywheels
Turn the engine manually BOTH directions to release the starter drive in case it has Locked Up.
*NOTE:
Users should always Fully Charge their battery with a battery charger and then try starting the engine before assuming it is something else.
Old Feb 14, 2006 | 11:50 AM
sixshootingexp
Thanks for the knowledge Million. I love my truck. I have decided to make sure the battery is charged first.
I couldnt get it to turn over manually so I am checking battery, then taking out the starter. I'll let you know.
Thanks again, love this sight. I know I could probabally find my answers somewhere within this sight, but I like the live replys much better.
Thanks...............sixshooter.................
Old Feb 14, 2006 | 11:53 AM
Mil1ion's Avatar
Mil1ion
I Love this SITE as well
Old Feb 14, 2006 | 02:13 PM
beartracks's Avatar
beartracks
I've had staters break the front bearing mount. If that happens it jams and you will have to pull it. I got so tired of replacing my "lifetime warranty" starter from Checker Auto I finally tossed it and used a mini starter.
Old Feb 14, 2006 | 03:07 PM
sixshootingexp
The front bearing mount on the starter is what it was. Remanufactured starter from bumper to bumper is now doing the job.
Thanks...........sixshooter..............
jeepy
Mar 4, 2014 03:38 PM
johncardi
May 6, 2011 07:23 PM
needhelp49
Aug 12, 2009 08:21 PM
panteramatt
28
Sep 24, 2003 08:20 PM
