Sponsored by: Auxito
engine rpm (towing)
Old Feb 12, 2006 | 10:19 PM
grippper's Avatar
grippper
Trailering
engine rpm (towing)
when i pull 3 snowmobiles my truck is running at 3,000 rpm
when im doing 73 mph. is this ok for the truck to run that high of rpm for hundreds of miles. its a 2003 f150 xlt fx4 withe the 5.4 and towing package.
Old Feb 12, 2006 | 10:20 PM
ford390gashog's Avatar
ford390gashog
well what rear end gear? is o/d on or off? 3k is nothing. but if its all flat land i would leave the o/d on.
Old Feb 12, 2006 | 10:36 PM
grippper's Avatar
grippper
Trailering
over drive is off. i tried putting it in overdrive but it kept shifting up and down. the tag says 355 gears but i think they have been changed.
Old Feb 12, 2006 | 10:37 PM
budman-mo's Avatar
budman-mo
You have a 4:10 rear end ratio.
That's what a towing package is all about, more power (more RPM), less gas mileage....What more could you want?
Old Feb 12, 2006 | 10:40 PM
ford390gashog
well no a 4.10 was not a option. the 4.10 only came in the 7700 trucks. the fx4 got 3.55 stock and 3.73 with tow package.
Old Feb 13, 2006 | 11:21 AM
7700Rob's Avatar
7700Rob
If it's shifting all the time, leave it out of O/D, like you're doing. Where you sledding at?
Old Feb 13, 2006 | 05:50 PM
budman-mo's Avatar
budman-mo
Get the axle code off the drivers door or door post and lets see what it is.
Old Feb 13, 2006 | 07:51 PM
grippper's Avatar
grippper
Trailering
starting in silver bay MN. and up to the canadian border.its great snowmobiling up there. i will get the tag off the door and post it. im pretty sher it says 355 gears, but i think they might have been changed.looks like the differential covers have been off. they have a bunch of blue rtv gasket sealer around them.
Old Feb 13, 2006 | 08:46 PM
budman-mo's Avatar
budman-mo
I based my 4:10 guess on your RPM.
Unless you have little tires that's about what it would be.
This last weekend I took a set of 4:10s out of an 2000 2wd Explorer I recently bought (stock gears). For some moronic reason that year Ford only put 4:10s in if you got the XLT package, like nice interior and trailer towing go hand in hand? Go figure.
Mine was turning 2800 at 70 MPH, in overdrive, that's with stock 255/16 tires.
I don't tow and just run down the road so I put in 3:27s, now it turns a little over 2000. So far so good, drives more like my last one now.
mongo75
Oct 4, 2011 08:41 AM
lawmac2005
Dec 9, 2010 05:56 PM
VAXB
Modular V10 (6.8l)
Aug 9, 2010 12:34 AM
KAS300
Apr 10, 2004 07:15 AM
CRITTERGITTER
Jan 30, 2000 10:14 AM
