RPM's & towing
Old Apr 7, 2004 | 09:47 AM
KAS300's Avatar
KAS300
RPM's & towing
Hey all,
A lot of times while towing, I'll come across hills steep enough that I cannot run 4th gear. My question is, how hard can you safely run the 300? My truck, at 55mph in 3rd gear, turns 3600 RPM. Usually I'll back off somewhere between 45 and 50, simply because I don't feel comfortable spinning that many RPM. Am I just being paranoid? Is it safe to run it that hard for 3-5 mile stretches?
Old Apr 7, 2004 | 11:12 AM
96hulk's Avatar
96hulk
re-gear your axles how much weight are you pulling?
Old Apr 7, 2004 | 12:56 PM
KAS300's Avatar
KAS300
Anything from 3-6,000lbs. The truck has a ZF 5-speed, 3.55 gears and 31" tires.
Old Apr 8, 2004 | 04:09 AM
Lectrocuted's Avatar
Lectrocuted
With that info if you regear to 4.11's, 4th gear should be around 2500-2600 at 55mph. I'm assuming that in 4th right now it's around 2200-2300 rpms.
Old Apr 8, 2004 | 05:33 AM
Ford_Six's Avatar
Ford_Six
I have run mine at about 4k for 2 hours straight, no adverse effects.
Old Apr 8, 2004 | 11:09 AM
TallPaul's Avatar
TallPaul
What motor oil and grade were you using?
Old Apr 8, 2004 | 07:48 PM
jessfactor's Avatar
jessfactor
Originally Posted by KAS300
Hey all,
you're loosing power at that high rpm. the 300 peaks its torque at about 2200 rpm's. 3500 is the peak horsepower, so it will go faster, but wont be able to pull as much. if you don't mind the slower accelerating keep the rpm's a little closer to 2200 rpm's.
the engine should be able to handle 3500 rpm's w/no problem.
Old Apr 8, 2004 | 08:49 PM
MEPR's Avatar
MEPR
while mud racing my 4.9L 4,000rpm isnt uncommon and i have had it blip up to 4,500rpm. Its still running strong, and for oil im running semi synthetic 10w30. As far as towing goes, i have found mine does its best at 1800-2500rpm. Im running 33" tires and 3.00 gears so that puts me right at 60-70mph and i have had no problem towing 4,000lbs.
Old Apr 8, 2004 | 10:00 PM
TallPaul's Avatar
TallPaul
I'd say the 300 is puttin down pretty good torque all the way from fast idle up to 3400 rpm. So by running higher rpms you are jacking up the horsepower which is needed to get the work done faster. Get yourself some high quality oil, maybe synthetic and not too thin, probably minimum 10w30, maybe 15w40. There used to be a company that used the 300 I6 in industrial applications like generators and their spec sheet said max sustained rpm, I think was 3400.
Old Apr 9, 2004 | 02:43 PM
KAS300's Avatar
KAS300
Thanks for the replies!
2200 RPM would mean driving around 50mph in 4th gear. Obviously thats not possible, otherwise I wouldn't have to shift to 3rd. If it would pull 4th I'd use 4th. Driving at around 30-35mph in 3rd equates to around 2200 RPM, but then whats the point? Doesn't matter to me if its fallen off the torque curve, as long as it can still accelerate and pull faster, I'll rev it out.
At 55mph in 4th, she's spinning about 2400 RPM. But then again, if I hit the base of a hill at 65mph in 4th, its turning about 2700 RPM, and it will still fall on its face, and I'll be in 3rd by the top of the hill. I think 4.10's would just prolong the inevitable for a few more hundred yards.
I think from now on, I'll try to curb my paranoia and let it rev a little more (and maybe keep a close eye on the heat guage ).
Old Apr 9, 2004 | 04:29 PM
Lectrocuted
Yeah. I got to thinking the same. My math was off a little. Pretty much at the limits of the old six. Need more power, Scotty. Keep your eyes on the gauges and your ears open. She's a tough old warhorse.
Old Apr 10, 2004 | 04:33 AM
Ford_Six's Avatar
Ford_Six
I ran (am still running) 10w40 Castrol. That is all this engine has seen the whole time I have had it.
At the time I did that, I was more concerned with doing 80+ than pulling a trailer. Although, on the way out here, I was turning about 3200 most of the time, six days straight. Everytime I got back on the highway, 5k was seen in first and second. I also did a few long pulls in second gear at 4k plus.
These engines are a lot more stout than they are given credit for, and if some breathing mods are made, they make decent power at the top end.
With a good balance job, and major intake and exhaust port and valve mods, I am looking at turning 7k out of my 300-6TT.
Old Apr 10, 2004 | 07:15 AM
TallPaul's Avatar
TallPaul
Good stuff. My 300 loves 10w40 too. Though I am going with a 15w40 this summer, I was suprised how well the 10w40 held up over 3000 miles last winter. A UOA on it showed the viscosity held right on the mark.
1951flatheaddave
19
Feb 9, 2025 03:02 AM
mongo75
Oct 4, 2011 08:41 AM
mongo75
Sep 27, 2011 09:17 AM
brider
16
May 8, 2005 05:55 AM
VintageBlueOval
Sep 17, 2004 04:43 AM
