Mass Air Flow Sensor Stock Vs Performance
Old Feb 12, 2006 | 08:16 PM
Camran's Avatar
Camran
Smile Mass Air Flow Sensor Stock Vs Performance
I have 2005 F150 FX4 5.4L with
Flowmaster Duals
AEM Brute Force Intake
SCT Xcalibrator 2 tuner (on order)
Curious if I need or should get performance Mass Air Flow Sensor?
Old Feb 12, 2006 | 11:19 PM
EPNCSU2006's Avatar
EPNCSU2006
Unless you are reaching the max airflow for the stock one, I don't see any reason to upgrade.
Old Feb 13, 2006 | 12:17 AM
Camran's Avatar
Camran
I believe the performance sensor is smaller than the stock one. Therefore impeding less on the flow of air through the intake. I'm not sure if there would be a noticable difference to justify spending $250-$400.
Suggestions Please
Thanks
Old Feb 13, 2006 | 01:10 AM
Blurry94's Avatar
Blurry94
An aftermarket MAF can hinder airflow if it is smaller than the inlet tract and throttle body. However, ther are many other (larger) sizes to choose from as well.
As Eric stated (EPNCSU2006), if the stock air meter isn't reaching 5volts, then there is no need to change it.
Selfhl1
Dec 8, 2015 10:13 AM
njtinman2
Oct 16, 2014 09:58 AM
strykert3c
1983 - 2012 Ranger & B-Series
May 28, 2014 11:53 PM
Competitor1
Nov 25, 2001 12:05 PM
