I'm gonna take a WAG and guess you have a driveability problem you're trying to fix. If you have pulled codes post them up so we can help solve the issue, and when I say post them up I mean the exact code numbers not whatever descriptions you have found for them. Also describe your issue as best you can.
X2......
Check for codes by running the Key On Engine Off (KOEO) tests and stored code (Continuous Memory aka CM) codes.
