Shocks
Old Feb 11, 2006 | 03:04 PM
jimkidd's Avatar
jimkidd
Shocks
I need some recomendations for my front and rear shocks. '95 cab & chassis DRW 2 wheel drive.
jimbo
Old Feb 11, 2006 | 03:07 PM
Roamineye's Avatar
Roamineye
jimbo
Bilsteins are good - you can price them at eshocks.com. I put them on mine and have been happy with them.
Old Feb 11, 2006 | 04:11 PM
plowhand's Avatar
plowhand
Playing in the Dirt
I have NAPA top of the line shocks on my 95 F250. Standard heavey duties on the front and coil overs on the back. I've run them for the past 8 months and like them. The coil overs work really good under a load, they did raise up the back of my truck about 1.5 inches from what it was with the old shocks. Hope this helps.
Old Feb 11, 2006 | 06:31 PM
1997F-350's Avatar
1997F-350
bilsteins for me also. save your receipt if you buy them. they have a lifetime warranty and will not honor it without a receipt. since your truck is a really stiff ride already they will be fine. mine are a little stiff with no load. but since your truck has twice the leafs ours do you wont even be able to notice.
Old Feb 13, 2006 | 11:21 AM
weldboy's Avatar
weldboy
Quick question on shocks....I'm planning to do a leveling kit on the front of my 96 F250 4x4. I think it will raise it 1-1/2" or so. Do I still order the stock shocks even with this slight lift?
Old Feb 13, 2006 | 02:43 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Stock shocks will work with 1 1/2" lift. I leveled mine and talked to the people at a shop that does lifts and they advised it would be alright since the lift is not over 2". Also due to the heavey springs on a 250 there is not that much travel anyway. So level it. It makes alot of differents in the look from outside and inside. You'll like it.
Old Feb 14, 2006 | 08:53 AM
weldboy's Avatar
weldboy
So I have been searching for good/bad opinions on Bilsteins on this forum, and it seems the general consensis is that Bilsteins are good but some dont think its worth the price. I generally drive 3/4 of the time on paved roads and the rest on gravel/dirt. My truck is already stiff. I just dont want to pay an extra 80 bucks that I could have put toward something else. Will the Bilsteins make any noticable difference? Will the 2" front leveling lift make a stiffer ride than I'm already experiencing? I'll gladly pay the extra if it makes a difference.
Thanks for the earlier reply plowhand.
Old Feb 14, 2006 | 10:10 AM
1997F-350's Avatar
1997F-350
your truck will probably ride smoother with an rsk. thats what they do. as far as stiff i was refering to jimkidds cab and chassis which is much stiffer ride than a normal 1 ton or 3/4 ton.
if your shocks arent worn dont replace em. chances are you got more than 100k on your truck and stock shocks they are wore out.
Bsherry
Escape & Escape Hybrid
Oct 23, 2013 07:45 AM
Chuck_Sloggett
Aug 31, 2007 11:28 PM
warmdye
Jul 17, 2002 06:07 PM
DrFord
Jun 12, 2002 09:24 PM
honney
1978 - 1996 Big Bronco
Nov 16, 2001 10:27 AM
