57-60 power steering conv,
Old Feb 11, 2006 | 08:03 AM
tbird4's Avatar
tbird4
Question 57-60 power steering conv,
Im building a 1958 f100 I would like to know my choices on having power steering
Old Feb 11, 2006 | 05:57 PM
Larry_the_handyman's Avatar
Larry_the_handyman
For myself, I'm using the pump and gearbox from a '85 F-350 b/c I have an extra and it's pretty simple. Lots of guys like the Toyota gearbox or the Volare. The steering is so straightforward that just about any unit will work. Are you running the stock front suspension or are you looking to change that out too?
Old Feb 11, 2006 | 08:41 PM
pootscratch89's Avatar
pootscratch89
I am currently in the process of installing the toyota conversion in my 57. I purchased the mounting kit and the pitman arm from CPP. I bought the toyota box from a wrecking yard in CA, just because no one had a new one! The only problem I forsee at this time is getting the ball stud off the pitman arm and having it taper drilled. Machine shops around here do not seem to be adequately equipped to do this. I may have to cut off the lower end of my original pitman arm and fab it into the new arm. I was told that No Limit sold a pitman arm without the stud, but they said they didn't have such a creature. I am trying to get this thing back together this weekend, so I will hopefully have some better info for you tomorrow or Monday. I'll try to take some pics as well.
Old Feb 11, 2006 | 11:26 PM
Col Flashman's Avatar
Col Flashman
These others are fine & dandy but, if you wish to stay Original Style, the Ram Assisst P/S System will Bolt right into place, so contact John F-Funhundred in Anaheim.
It's really the Best way to go, as you do not have to Cut, Hack, nor Weld a bleedin' thing, just bolt it right up.
Old Feb 12, 2006 | 12:57 AM
Larry_the_handyman
Where is the fun in that?!?
Old Feb 12, 2006 | 08:48 AM
Walston's Avatar
Walston
Pootscratch,
See my gallery for making a pitman arm. You want to make sure the length is the same size of the original Ford so the turning radius is correct.
Old Feb 12, 2006 | 11:58 AM
AXracer's Avatar
AXracer
Or buy a conversion pitman arm from Mid Fifty.
PM your email addy to ferguson 777 for a preview copy of our steering options tech article.
Old Feb 14, 2006 | 09:03 PM
Roy in TX's Avatar
Roy in TX
Power steering
Thinking of putting that ram assisst unit on my 57, but dont have $1200.00 available right now. How does that set up work ? What pumps the fluid, and how does it pump ?
Old Feb 14, 2006 | 11:54 PM
Col Flashman
If you go to John's F-Funhundred I'm quite sure he would be able to get it for you @ a better price than that.
Standard late '50s FoMoCo P/S Pump, Brackets & Pullies if you are powered by an 8 or you need to find the harder to locate I-6 Brackets & Pullies, but still use the same P/S Pump.
Old Feb 15, 2006 | 05:06 AM
Roy in TX's Avatar
Roy in TX
Power Steering
The price I mentioned was from Johns Fun-onehundred on-line catalog (1200.00) and that didnt include the pump or brackets. I will go back and check again, could have been a misprint I suppose. Thanks , one of your comments was what started me looking at this Ram Assist sys. I am trying to keep my 57 as orginal as possible, but I sure would like PS. Just rebuilt my steering unit, but its still tiring to drive in this city traffic, I use my truck daily. Thanks , later. Roy
Old Feb 15, 2006 | 02:39 PM
Col Flashman
Actually, that's his Old price & it also states that he no longer carries them.
BUT, if you call & talk to John personally & tell him I sent you, I'm quite certain you'll work out something better.
Old Feb 15, 2006 | 02:57 PM
Roy in TX's Avatar
Roy in TX
57 power steering
Yeh, I noticed that the printed catalog indicated DISC, however, the on-line catalog had the price. Either way its a lot, I'm considering other options. Thanks Roy.
Old Feb 15, 2006 | 03:24 PM
Col Flashman
The On-Line catalog also has Discontinued in there as well for the '57-'60 truck & he's worked w/ others I've sent to him because he's the best to deal w/ concerning parts for our years of trucks.
There are others that have the same Ram Assist System but aren't as easy to deal w/.
Good Luck.
Old Feb 15, 2006 | 06:20 PM
Roy in TX's Avatar
Roy in TX
power steering
I will be talking to John. Thanks for your help. Roy.
stepside
Mar 12, 2002 10:13 AM
bjoern
Aug 9, 2001 01:20 AM
otto
Feb 1, 2001 09:33 AM
jowilker
Feb 15, 2000 08:41 PM
BigBrownTruck
Oct 27, 1999 12:35 PM
