tires
Old May 27, 2001 | 03:46 PM
slothshady's Avatar
slothshady
tires
what are the biggest tires i could fit on a 77 f250 without getting a lift kit?
Old May 27, 2001 | 04:28 PM
EJonesJr's Avatar
EJonesJr
tires
35's should fit
Old May 27, 2001 | 04:51 PM
slothshady's Avatar
slothshady
tires
ok thanks
Old May 27, 2001 | 08:54 PM
doc_f250's Avatar
doc_f250
tires
My '78 2wd runs 33x12.50x16.5 all the way around w/o mods. So if yours is a 4wd, 35's should fit. Doc
Old May 27, 2001 | 10:16 PM
slothshady's Avatar
slothshady
tires
mine is 2wd
Old May 28, 2001 | 09:16 PM
earthworms's Avatar
earthworms
tires
I am not sure about 35's but 33's would fit just right on a 2wd
Jake
Old May 29, 2001 | 07:12 PM
79fordslug's Avatar
79fordslug
tires
I have a 79 F150 2wd with 31x10.5 and it looks pretty tight without a lift. Will 33's really fit? what kind of travel do you have? I use mine as a daily driver and would not stomp off road, but I still want a little play. Will They Really Fit?
Old May 30, 2001 | 02:10 AM
earthworms's Avatar
earthworms
tires
79fordslug: I am not positive if 33's would fit. If your 31's are tight, then 33's probably wouldn't fit. Some 33's are really around 32 inches high. They just round it up to 33. A 2 inch body lift would make room for 33's.
Jake
Old Jun 1, 2001 | 04:22 PM
shorthair's Avatar
shorthair
tires
I run 36" buckshots with out any lift but you must shorten your steering stops or the tires will rub on the front springs at full lock.
Old Jun 1, 2001 | 11:06 PM
doc_f250's Avatar
doc_f250
tires
79fordslug,
The F-250's sit higher than most of the comperable F-100's or F-150's. My '78 F-250 2wd has plenty of clearance turning & ditch runnin' It all depends on the individual truck (spring sag, etc.) Hope this helps, Doc
Old Jun 2, 2001 | 10:38 AM
79fordslug's Avatar
79fordslug
tires
I am pretty sure that I could get 32" to fit without too much trouble, but I don't want to lift the truck as it is so expensive to lift the front end with the twin I beams. I need to replace my body mounts and I am probably going to get poly bushings. Maybe that will restore me an inch so I can squeeze new rubber in there. Thanks for the posts guys.
Old Jun 3, 2001 | 09:57 PM
adobbs's Avatar
adobbs
tires
Old Jun 4, 2001 | 01:15 AM
tamwill's Avatar
tamwill
tires
Does anyone know what is the widest PERFORMANCE tire that will fit in the fenderwells without affecting turning radius too much? My truck already takes a city block to turn around. How about 285/65/16? Whatta ya think?
'70 F-250 Camper Special 360/C-6, 3.73, 8 mpg uphill or down
xaviar
Oct 17, 2012 08:36 AM
Splash67
Jun 1, 2010 03:12 PM
superdutymjh
Mar 12, 2003 09:13 AM
rabbit stu
Mar 22, 2001 10:34 PM
justdrive1
1997 - 2003 F150
Nov 9, 2000 12:27 PM
