TPS sensor voltage low.....
Old Feb 10, 2006 | 09:54 AM
turbonova1972's Avatar
turbonova1972
I've recently installed an Edge Juice w/attitude on my 7.3 E350 van and had to tap into the TPS signal wire because the "y" connector supplied with the installation kit wasn't the same on the vans i guess, o well. But the problem im having is the TPS signal voltage only seems to be 3.7 at WOT, could it be a bad TPS or maybe a bad meter perhaps. Edge said it was the middle grey and white wire on the connector and the voltage DOES move up and down as i move the throttle so I know its the signal wire. Any help would be appreciated, thanks.
javi2001
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 5, 2012 12:44 PM
Bradlee7.3
Feb 16, 2012 11:35 AM
Hoostie
Nov 10, 2006 07:30 PM
turbonova1972
Feb 6, 2006 10:08 AM
