First off I have to say what a pain not being able to search.
My question is, I just installed the edge with attitude on my 2003 ps 7.3 and I keep throwing a code p0122 which is low voltage for the tps sensor. Per the edge insturctions you have piggyback into this with their supplied harness. Well the problem is that their directions do not show you the connector for a truck with power pedals. It looks like the harness I needed, and the connections fit so I used it. The truck did not like that. So, I was wondering if anyone knew where the tps wire is located, and what color it is. I just need a wiring diagram, and I can not seem to find it on the web. I just want to know what wire it is, and I will splice into it, and soder the connections so I know I have the right wire. THnaks a lot.
I did my buddies 01 and remeber having the same trouble. There are 2 harnesses form Edge. We had to wait for the right one to work OK on his. Not sure if this pertains to yours tho.
These are the wire colors on his TPS. Not sure if your's is the same.
Brown White BR/W V-REF (5VOLTS IIRC)
Grey/Whiite GY/W AP SIGNAL
Yello/White Y/W GROUND
