Why do I keep burning out diodes in my alternator?
Originally Posted by rebocardo
Bad ground or bad positive cable that for a moment disconnects the alternator (or a load) from the battery system when you hit a bump. When the load or battery reconnects to the alternator it blows the diode.
The amp rating on newer small frame alternators is only an intermittent rating. The older alternators were often rated continuous amps. Overloading newer alternators is quite common which results in burned out diodes. They just do not have the heatsinks necessary to do the job.
Brickster68
22
07-30-2017 05:29 PM
fordbozo
26
11-20-2015 06:50 PM
02GrayPowerStroke
02-02-2010 08:56 AM
