Alternator diode fails
Old May 5, 2004 | 10:03 AM
rcain1's Avatar
rcain1
My battery light onthe dashboard comes on and goes off ever so often. I took the truck to Advanced Auto and they checked the batteries and the alternator. The batteries were OK and the alternator only came up with a "diode fail". I have not been losing any voltage in my batteries over the past month. I guess that the batteries are getting charged.
My question is: Is the alternator "fixable? or Has anybody ever had this issue? Thanks!!
Old May 5, 2004 | 11:54 AM
powerstrokefreak's Avatar
powerstrokefreak
I think that the only way you can fix the diode is to buy a new alternator. If the altenator is still under warranty you will void that warranty when you split the case.
Old May 5, 2004 | 05:23 PM
tjbeggs's Avatar
tjbeggs
you should have the alternator fixed or replaced. bad diodes can hurt the battery while still charging them. you could get a whole new alternator or have it rebuild by a alternator shop. had mine done on 95 psd and it cost me about $90 i had no idea mine was bad except i installed amps and aftermarket radio and had engine noise.
good luck
tjbeggs
Old May 5, 2004 | 07:48 PM
FarmerPhilCo's Avatar
FarmerPhilCo
ford has a prob with their 98-00 modle alts for some reason that I have noticed, mine and my buddys police cars had bad diodes and i have seen a number of trucks with bad diodes. they do and dont have the potential to harm your bats, just depends. I would go ahead and replace it
command37
Jan 9, 2016 09:36 AM
One Sock
Electrical Systems/Wiring
Feb 19, 2012 08:47 AM
mck99f250
Jun 15, 2011 07:38 PM
diablo7308
2004 - 2008 F150
Jul 9, 2010 06:31 PM
02GrayPowerStroke
Feb 2, 2010 08:56 AM
