c-6 band question
Old Feb 9, 2006 | 10:48 PM
TimeEater's Avatar
TimeEater
c-6 band question
Auto c-6, is it the band if it wont shift from 1-2 but can get to second from selecting 2 on the shifter. Or am I just ready for a rebuild. Just curius before I get under there.
Old Feb 10, 2006 | 02:07 AM
fastford59's Avatar
fastford59
check the modulator valveand vaccum going to carb.also check kickdown lever.
Old Feb 10, 2006 | 08:29 AM
TimeEater's Avatar
TimeEater
where is the modulator valve at? there was a vacuum line that came from the back of the carb, the power brake line I thought, that ended at the middle of the tranny and no connection. maybe this is the line your talking about. i was having carb problems too and plugged up that line and tightened down the manifold and the carb problems went away. maybe slipped off something?
Old Feb 10, 2006 | 06:11 PM
rclarke's Avatar
rclarke
The vacumn modulator is on the rear of the transmission, the vacumn should be hooked to manifold vacumn. If it is not hooked up you will not get upshifts except at extreme throttle.
Old Feb 10, 2006 | 06:58 PM
TimeEater's Avatar
TimeEater
Well got under there and sure enough that is what it was. Must have popped off. Thanks for the help.
steves_F350_460
Apr 23, 2010 10:16 AM
karljay
Feb 10, 2005 03:24 PM
mrmort
Sep 7, 2004 12:53 PM
rehf100
Nov 20, 2003 09:35 AM
the law
Sep 19, 2002 10:04 PM
