02 Explorer XLT tailgate plastic trim
Old Feb 9, 2006 | 07:22 PM
jdwheels's Avatar
jdwheels
There is a plastic piece of trim that runs from below the rear wiper through the blue oval down to the lift handle for the glass window. Ours just devoloped a crack all the way down. It seems to be just the plastic piece. Anyone have this happen? Or know a web site with a parts breakout. I know the dealer will charge a arm and a leg.
Thanks
Old Feb 9, 2006 | 08:11 PM
MountaineerAWD's Avatar
MountaineerAWD
Cool
extreamly common on the 02-05 Explorers and Mountaineers. I have an 02 Mountaineer and had that brake on me too. Most every 02 owner has had it brake. Its cost roughly 300 bucks to put a new plastic part on and repaint it from the dealer, there is a TSB on this as well. This is one of Fords defects they have not owned up to yet and make a recall about this!
Old Feb 9, 2006 | 10:46 PM
Exploder02's Avatar
Exploder02
Yep, I had to replace the one on my '02. cost me 250 at the dealer, painted to match, etc, installed. Don't let a dealer try to tell you that you have to replace the whole glass, or the tailgate (that used to be the fix long ago)... I had an argument with another dealer here in town over it, changed dealerships, got it fixed. Another instance of poor engineering on these trucks... Good news is, I believe that they're using a different plastic in the new part that doesn't crack like the old one... temperature extremes seem to bring it on.. when mine cracked, the crack would totally close up in full sun, when it was colder, like around 35 degrees, you could stick your finger in it.. who comes up with this crap?
Old Feb 10, 2006 | 06:07 AM
DetailerDave's Avatar
DetailerDave
Mine is also cracked. 02 Explorer.
Old Feb 10, 2006 | 09:02 AM
jdwheels's Avatar
jdwheels
Just talked to dealer, only 3/36 coverage on this. $350 to repair. Wow, sounds like a engeering design defect that should be covered.
Old Feb 10, 2006 | 09:55 AM
TadpoleMN's Avatar
TadpoleMN
Mine was replaced along with the shattered rear window last Wednesday. Total bill came to $1500. Luckily since there was glass breakage insurance covered it. Sucky design from Ford, sucky service from Ford.
Old Feb 10, 2006 | 12:11 PM
MountaineerAWD
did you have Ford do the recall before the window broke on you?
Old Feb 13, 2006 | 11:30 AM
TadpoleMN's Avatar
TadpoleMN
Yes, that was done over a year ago. Thats why Ford says take a leap. They don't want to admit there is still a problem.
Old Apr 4, 2006 | 09:47 PM
jgurland's Avatar
jgurland
Mine was cracked, too ('02 Explorer) and I showed the dealer when I was there for other service. He told me it was a design flaw and that they would replace it for free. Sure enough, they ordered the part, painted it and installed it free of charge. Maybe they just felt bad about charging me a gazillion dollars for the other repairs.
Old May 19, 2006 | 02:05 PM
Timberline's Avatar
Timberline
Does anyone have the full text of the TSB referring to the cracked panel? The number is 15892 and the NHTSA ID is #637771.
Uni Moe
May 12, 2016 01:00 PM
02X
Mar 26, 2014 02:44 PM
Mudrat_Explorer
Oct 22, 2013 06:05 PM
presidentsdad
Sep 16, 2010 11:34 PM
schap
Apr 24, 2007 03:56 PM
