Bronco II Ford Bronco II
thermostat problem
Old Feb 8, 2006 | 09:57 PM
my72ford's Avatar
my72ford
thermostat problem
i have a 1986 bronco II 2.9l thus far i have replaced radiator,water pump,thermostat..as long as the thermostat is removed,the temp guage barely moves,with thermostat in guage is pegged..could it be a bad senging unit?? is there a procedure to check it thanks for any ideas!
Old Feb 8, 2006 | 10:06 PM
Rancheroracer's Avatar
Rancheroracer
You could pull the sending unit, hang it in some water, heat the water to boil & see what your gauge does. Remember to ground the sender to complete the circuit. You could also check your thermostat this way.
Old Feb 9, 2006 | 07:00 PM
my72ford's Avatar
my72ford
thermostat problem
thanks for the idea! i didn't thin kabout doing it that way,will do it this weekend. thanks again for the info
Old Feb 10, 2006 | 10:02 AM
kernel-panic's Avatar
kernel-panic
Sounds more like the thermostat is stuck shut OR is the wrong temperature for your climate. It sounds as if your radiator cap is holding and venting to the overflow (?). Leaving it out of the engine though... will eventually lead to overheating.
Old Feb 11, 2006 | 10:24 PM
bronocIInoob's Avatar
bronocIInoob
dont do a risk to overheat your bronco as you may know the head will most likley crack
boaterbob
Dec 7, 2010 07:31 AM
PROSTOCK
Dec 19, 2007 08:37 PM
bassmanatcs
1978 - 1996 Big Bronco
Aug 8, 2005 02:54 AM
HINLSEY
Nov 29, 2004 01:12 AM
BigMacZack
Jan 19, 2004 01:11 PM
