Replacing rear sliding window
Rear Window
You will want to do a search on this site how to remove the backrest of the rear seat. It will be necessary to remove this to take out the rear window. You will not be able to remove the backrest with out having instructions on how to do it, even then it is difficult the first time.
Replacing the window also looks tricky, I'd recommend going with a pro after you removed the backrest for them.
Good Luck
Good Luck
flat4vw
01-09-2010 06:45 AM
