Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Things Not to Do In Your Garage...........
Old 08-29-2003, 08:55 PM
furbis's Avatar
furbis
furbis is offline
I did not see anyone mention don't weld next to a charging battery, me and dad came around the corner of the shop to see our truckdriver whith his head underneath the water hydrant because he was welding 12" away from a charging battery, thankfully he was not hurt the welding hood protected his head and face.
something else I recently learned was don't agree to let the former house cat take up residence in your shop you will have cat hair all over everything.
also if you are going to back your johndeere "B" into your shop that has sliding doors make sure you open them far enough to clear the axel that is sticking out past the tire you can't see over.
when trying to seat the bead on a large tubeless sprinkler tire don't use to much either it will bounce it 3 to 4 feet off the floor and might damage something or someone.
  #137
Old 08-30-2003, 02:39 PM
povphile's Avatar
povphile
povphile is offline
Always use a second support. Put and extra jackstand uner the crossmember. Do not rely on the hold properties advertised.
Wear Safety Glasses or shields. I have two boys, 5 and 7. They have their own Glasses with their names on them that thy put on whenever I am in the shop.
Dont attemp to change the iol filter on a 80's era or mazda with out welding gloves. They put the oil filter above the Cat Converter.
  #138
Old 08-30-2003, 10:33 PM
craterjoe's Avatar
craterjoe
craterjoe is offline
of course they do this while they are still in the house watching Toon Disney.........
  #139
Old 09-01-2003, 08:42 PM
schriffs's Avatar
schriffs
schriffs is offline
Don't lift the back of the truck with a floor jack when the front is up on ramps, my buddy was hurting for weeks after it rolled down the ramps and pinned him against the door. luckily he managed to wiggle himself out, but the door has a nice bend in it. With that in mind, try to have your friend, spouse, whoever, check on you every so often when working alone, particularly when welding, working under stuff, operating any equipment.
  #140
Old 09-04-2003, 04:39 PM
crosswind's Avatar
crosswind
crosswind is offline
never refill your crankcase with oil until you are sure you replaced the drain plug..........especially when your inside your garage.........
  #141
Old 09-04-2003, 06:41 PM
muscletruck7379's Avatar
muscletruck7379
muscletruck7379 is offline
been there, done that, hope It never happens again.(but everyone knows it will)makes you kinda wonder why theres nothing on the dipstick!
  #142
Old 09-17-2003, 12:32 PM
will-work -for-mud's Avatar
will-work -for-mud
will-work -for-mud is offline
make sure all doors on vehicle are closed before backing out of the garage.
make sure garage door is up before backing out.
either of these is very expensive.
also never put a swivel socket on a 1/2 inch drive impact gun a pull the trigger to make sure its goin the right way. could shatter a windshield.
  #143
Old 09-17-2003, 12:51 PM
will-work -for-mud
oh yea by the way...when welding on a vehicle remember to take the negative off the battery post. also when welding remember to place the negative clamp near where u are welding. my buddy pu his on the front bumper when he was welding toward the back of the truck. the electricity moved through the engine and spot welded the crank in place. also very expensive.
  #144
Old 09-18-2003, 05:38 PM
Bronco 81's Avatar
Bronco 81
Bronco 81 is offline
laquer thiner === lighter fluid............
DEFINATELY A NO...NO
  #145
Old 09-19-2003, 01:13 PM
ZRX61's Avatar
ZRX61
ZRX61 is offline
However.. 100LL AvGas is a YES...YES
  #146
Old 09-19-2003, 02:30 PM
RockyMtnF250's Avatar
RockyMtnF250
RockyMtnF250 is offline
Do not think that several 5 gallon buckets of used motor oil are going to hold down the tarps that enclose your carport! Zoning cops told my buddy that if they could not see his un-licensed 67 Newport from the alley that it would be OK. Park the non-running Newport, hang tarps, place buckets of motor oil on bottom of tarps to hold them down. OK until............
Big wind/rain storm hits Colorado Springs, tarps become very effective sails and overturn buckets, yeah sounds like a mess but wait. The unfettered tarps are blowing in the wind, slapping the concrete and lapping up the oil, at the end of the excursion of the tarp blowing in the wind the tarp lets loose the oil and covers every thing for 20 feet, including the car. Then it starts raining cats and dogs! No oil dry to be had. Of course the car is under the carport so the rain is not going to help wash off the oil. Days and days to cleanup this environmental disaster. Laughed until I cried as he was on the phone explaining this while it was happening. Now when he makes a mess I call him Captain Hazelwood of the Exxon Valdez.
  #147
Old 09-20-2003, 01:25 AM
haroutd's Avatar
haroutd
haroutd is offline
Location: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
He should be happy he didn't get in trouble for all that spilled oil!
If you're going to have a circuit breaker go off in the garage because you have too many things plugged in, make sure you used a quality electricial to do your wiring. My friend had that problem in his garage -- turns out during a renovation, the junction box leading to the garage was buried in a wall/ceiling somewhere. The surge of electricity apparently caused a brown-out in the junction box (probably bad connection, arcing, who knows...) rather than tripping the breaker. We never did find where that junction got buried, and had to call in a favor from an electrician friend to bring a new power source into the garage from the panel, and disconnect the prior one. What a PITA that was! Troubleshooting, metering every outlet junction we could find, and in the end snaking in a new line. Just because a foolish contractor buried a junction box with drywall rather than put a cover on it. I could strangle that man.
  #148
Old 09-20-2003, 02:34 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
That is definitely a NO NO, and against the electrical code -hehe
I am surprised the Electrician couldn't just trace the wire with one of those RF wire tracking setups.
  #149
Old 10-10-2003, 07:44 PM
Bargod's Avatar
Bargod
Bargod is offline
*bumps thread
Sorry but I love this thread, I couldn't stand to let it disappear.
  #150
Old 10-11-2003, 01:21 PM
8lugnutz's Avatar
8lugnutz
8lugnutz is offline
OK. It's been said already, but It bears repeating.
I have this problem. My step-son is constantly taking things apart "just because". Well his latest adventure was taking apart his brother's Yamaha motorcycle, and stripping out 3 bolts while putting it back together. I used a Dremel tool cut-off wheel to cut the bolts off, getting a piece of the wheel embedded in my cornea I knew I had something in my eye, but thought it was an eyelash. Five days of aggravation, 4 trips to the optometrist, 2 days of missed work, and $85 could have been prevented by a $5.99 pair of safety goggles, which my wife bought and ever so conspicuously placed on my workbench with a 3' x 5' sign that says "YOU HAVE TO *WEAR* THEM HONEY!"
so......
ALWAYS, ALWAYS, ALWAYS wear safety glasses.....even if you hate them!
BTW, the boys don't take things apart for no reason anymore!
Quick Reply: Things Not to Do In Your Garage...........
