new toy
Old Feb 7, 2006 | 05:16 PM
capt'nben's Avatar
capt'nben
Smile new toy
I just bought a 50 F1, my dad had one back when I was a kid and I learned to drive in it.
The truck I bought is a project and I am just starting to plan it, it will be finished to look like dad's the old green stock color not lowered much, stock interior, ect.
Front end will be converted to IFS and I'm looking for advise on which way to go.
Power plant is wide open, I have a 90 Ranger with a 92 Mustang and AOD4 in it, I like fuel injection and overdrive but I'd like a bit more torque as I think I'll use this little truck to pull a car trailer and haul my 32 roadster, mabe a 351 winsor with EFI would be enough, comments please.
Ben
Old Feb 7, 2006 | 05:42 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 7, 2006 | 05:46 PM
cbfomoco's Avatar
cbfomoco
cangrads now lest see some pictures.
49willard's Avatar
49willard
Take a look at the Jaguar XJ IRS. It fits beautifully in the 48-52 chassis. Search on Jaguar.
Old Feb 7, 2006 | 06:01 PM
1949f1's Avatar
1949f1
welcome, my story is about the same,the pic in top left corner of my post was my dad's 50 f1. i am doing my 49 with minor mod's and painting it the same color. going with a 302 and c4 trans. power brake's and disc up frt. good luck on your's
Old Feb 7, 2006 | 07:03 PM
AXracer's Avatar
AXracer
Hi! If you don't want to lower it much, then the very easiest and best solution would be to rebuild the stock front axle and suspension remove some leaves or replace the springs with new ones, add power steering to it, and it would then drive and handle as well as your Ranger. You'll find that any of the popular IFS conversions will drop it quite a bit. If you don't mind a fair lowering then 49 Willard has the answer, the Jag fits like it was made for it and you can't beat the price, plus it's a better IFS for our trucks than any aftermarket one based on the MII. You planning an open or enclosed trailer for the 32? How far you planning on towing, over what kind of terrain? Just checked you're in CO, the 351 will be lacking in torque for pulling over the mountains and at high elevations, especially with an automatic and an enclosed trailer IMHO.
a good 460 with a C6 would be cheaper and make you a lot happier. My other suggestion if you want to go with the 351 (a good engine, and normally would be my choice) would be to forget the automatic and pop for a T56 6 speed and a 4.10 rear gear. The two overdrives will give you the ability to pull a low rear gear for towing without eating you alive at the gas pump. but would mean shifting yourself. That's basically the setup I'm using for towing an enclosed trailer but our mountains aren't near the challenge.
Old Feb 7, 2006 | 10:15 PM
kdmcinnes's Avatar
kdmcinnes
Welcome to FTE, Congrats on the new baby! You will get lots of good insight from all here. Lets see some pics.
Kyle
Old Feb 7, 2006 | 10:31 PM
rhopper's Avatar
rhopper
Welcome Capt'n. Where in co do you live? Danny in CO is in Larkspur, RHW lives in co springs, and I'm in Peyton. I'm doing a similar project with a 48 f-1, and I've done lots of research on the questions you're asking. PM me and I'll share.-Rusty
Old Feb 8, 2006 | 08:01 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Originally Posted by AXracer
Hi! If you don't want to lower it much, then the very easiest and best solution would be to rebuild the stock front axle and suspension remove some leaves or replace the springs with new ones, add power steering to it, and it would then drive and handle as well as your Ranger..
If I were the aggressive, argumentive type I'd challenge that statement. But, since I'm not, I'll just say that in my own opinion regardless of what you do to that straight axle it is highly unlikely to drive and handle like your Ranger...
Vern
Old Feb 8, 2006 | 08:57 AM
51ford fan's Avatar
51ford fan
Capt'nben Welcome to the forum
Old Feb 8, 2006 | 09:53 AM
capt'nben's Avatar
capt'nben
I live in Brighton, just northeast of Denver.
Thanks for the reply
Old Feb 8, 2006 | 10:02 AM
Danny in CO's Avatar
Danny in CO
Smile
Welcome! We're not too far apart. As Rusty said, I'm in Larkspur just off I25. My almost 16 year old son (and I) have a 49 F-3 that we are restoring. We have the stock 6 cylinder about ready to put back together. We still have a lot of body work and brake work to go. We also have a 51/52 frame and cab that has supplied some parts.
Danny
Old Feb 8, 2006 | 11:00 AM
Earl's Avatar
Earl
Welcome to the forum. You've met some of the folks and the rest are just as helpful and nice. When you get a chance, set up your gallery so we can see your project.
baker1983
16
Dec 30, 2020 11:13 AM
77 Dent
New Member Introductions
Aug 15, 2014 10:05 AM
cire1
23
Nov 13, 2012 02:10 PM
MBBFord
2004 - 2008 F150
May 1, 2007 11:20 PM
Cobyhoff
Sep 23, 2003 09:04 PM
