Hey guys my dad just bought a e99 all stock looking for some cheaper easy mods to do to it im gona do a 6637 and open exh. its his dd and camper hauler thanks in advance
Honestly bro, with the 6637 and open exhaust, thats about all i'd do as far as mods, since your looking for "cheap" mods. No offense, but depending on what you might consider cheap, thats about it..(its all i could afford as far as cheap). However, i'd put my $$$ toward preventative maintenance. Depending on miles on ride..etc, take a gander at RIFFRAFFDIESEL.COM, and check out the "cabinet kit". Gives just about every o-ring needed for the turbo, hpop, and fuel bowl, for where leaks are notorious for happening. The truck gots plenty of power for what it sounds like your throwing at it, so personally, i'd go for the "reliability" avenue....Congrats and welcome to the forum.
Ok thanks ya his truck has a fuel bowl leak im gona rebuilt that for him other then that all is good w 105k on it i just didn know if there was anything dif to do to it then an my obs 96 is a ts style chip about the best for the e99 as well he had a hypertech on it when he bout it and i took it off cause there r no gauges and exh is opened up
It is an industrial open airfilter that you can get at Napa for a hefty price or go through Riff Raff Diesel and get the pre-filter net that goes over the filter. I just added one on my wife's 7.3 Excursion. We just bought it and it had a KN filter setup, I kept the intake tube but changed out thr filter based on bad reviews and maintenance issues with the KN filter. On my 7.3 F350, I used the AIS system from Riff Raff.
6637 is the napa pn for an air filter, adopted as a modification in the 7.3 world used to remedy broken tabs common on the oem box and feed the turbo more air. Donaldson b085011 is superior and the Donaldson blue, exclusive to riff raff, even more so. Some other variants exist out there but 6637 has a simplistic ring to it to represent a common appearance and objective.
I would look at doing the Hutch and Harpon mods inside the tank, they are cheap and you might prevent him from having a problem later. The one you only need a plastic pipe cutter and the other you can do with hardware store components, no need to but a kit.
Reps sent for providing a well thought out answer with details pertaining to the source and function of the part.
