Excursion Handling
Old Mar 10, 2006 | 08:51 AM
  #61
Matt M, PA's Avatar
Matt M, PA
I just ordered the Roadmaster ACtive Suspension for my '05, since it has a sway bar already.
I'll post here how that works out,.
Old Mar 10, 2006 | 12:32 PM
  #62
2005X's Avatar
2005X
"Roadmaster Active Suspension" Batman? Am I the only one that doesn't know what this is?
Old Mar 10, 2006 | 01:41 PM
  #63
Matt M, PA's Avatar
Matt M, PA
2005X....
www.activesuspension.com
Old Mar 11, 2006 | 03:20 PM
  #64
XNrepair's Avatar
XNrepair
Just put on the Hellwig sway bar on and I am very pleased ! Going around corners is night and day, she corners like she's on rales ....... well, it's a lot better now anyway .
Old Mar 11, 2006 | 04:33 PM
  #65
post-man's Avatar
post-man
XNrepair, was this a replacement of the stock bar or a net new bar, on what year X?
Old Mar 11, 2006 | 05:27 PM
  #66
XNrepair's Avatar
XNrepair
Net new. '03 2WD 6.0 did not come with rear sway bar stock w/o some optional tow package ?? HIGHLY recommended !
Old Mar 11, 2006 | 06:43 PM
  #67
Jim Hughes's Avatar
Jim Hughes
What are the best frt.and rear springs to install on my 2000 v 10 with 50,000miles. Ford guy but very upset with the ride and handling of my EX.
Old Mar 11, 2006 | 07:26 PM
  #68
aklim's Avatar
aklim
I have had GMs for a long time. The 02 Suburban was a lot better. The ride and handling of my EX is not the greatest either which was partly why I broke up with her. My Excursion ride also leaves a bit to be desired.
The problem with puting good frt and rear springs is that when you do put F250 springs or go to a Spring shop and tell them you want a heavier spring, you now have a very stiff ride all the way. That would be great for if you are towing a huge load in the bed and behind but what about when you are empty? Maybe airbags are the answer where you can inflate and deflate them as needed?
Old Mar 11, 2006 | 09:34 PM
  #69
XNrepair's Avatar
XNrepair
I'll have to agree, I have airbags and anit-sway and it has made all the difference in the world. Read through this forum and "tuff country traction bars" and you will have some great idea's for a new ride .
Old Mar 15, 2006 | 07:06 PM
  #70
MrCig's Avatar
MrCig
Just thought keep you all updated. Towed my boat this weekend the Hellwig sway bar made a big difference. We had 30+ mph cross winds and it was much more stable then before.
Mark
Old Mar 16, 2006 | 06:17 AM
  #71
Fords4Me's Avatar
Fords4Me
V code front B code rear from a late '99-'02 F-250/350 for a 4wd. I can't answer for a 2wd.
Old May 11, 2006 | 06:27 PM
  #72
MrCig's Avatar
MrCig
Got my Bilsteins shocks today am going to put them on next week. I will let everyone how it works out. Should be towing the boat the following weekend. that will tell all.
Mark
Old May 16, 2006 | 09:47 PM
  #73
Jim Hughes's Avatar
Jim Hughes
How much higher does the 2000 V10 EX. sit when I will install the V code front and B code rear springs.
Thanks
Jim
Old May 18, 2006 | 06:51 PM
  #74
MrCig's Avatar
MrCig
Well I got the Bilstein's on yesterday. I only drove the truck about 5 miles and what a difference.
I will be driving about 300 miles this weekend empty so I will see how it is.
Then the following weekend will be the test I will be towing my 38 foot boat.
That will be the ultimate test.
Mark
Old May 21, 2006 | 04:33 PM
  #75
MrCig's Avatar
MrCig
Well ran the Ex this weekend and I am very happy with the news shocks. I was actually able to let go of the wheel and the truck stayed in it's lane.
Mark
