2005 6.0 Shut Down
Old Feb 6, 2006 | 07:51 PM
southern pride's Avatar
southern pride
Question 2005 6.0 Shut Down
I have a 2005 6.0 and I was driving today and it just shutoff with no warning at all. I coasted of the road and the truck started back up. I drove it the rest of the day and no problem. Has anyone else had this happen?
Old Feb 6, 2006 | 10:09 PM
Fully_Loaded's Avatar
Fully_Loaded
Could have just been a computer glitch
Old Feb 8, 2006 | 08:56 PM
LordBlade's Avatar
LordBlade
I saw this once on a new truck. The fuse or the relay for the fuel pump was loose. Can not remember which one. Doubt that is your issue. But you can take a quick peek.
Old Feb 8, 2006 | 10:13 PM
SD luvr's Avatar
SD luvr
Same thing happened on my '04. I was downhilll on a mountain grade in a curve and it died. I was headed across the double yellow lines into oncoming traffic and manhandled it over to the r/shoulder. As I was coasting to a stop it started by itself. I took it to the dealer and they reflashed the computer with an update. That was last May and it hasn't happened since. As I recall, about 2 weeks later a TSB came out advising of that same problem. My advice? Take it to the dealer and check for any updates.
Old Feb 9, 2006 | 04:24 PM
BIGJB's Avatar
BIGJB
I Had The Same Thing Happen To Me Twice. Both Times I Was Making A Turn And Was On The Gas Then When I Let Off The Car Stalled. It Did Start Right Up After This Happened.
Old Feb 9, 2006 | 06:22 PM
southern pride
I took the truck in on tuesday. After telling them about it shutting off they looked it up and told me I had four recalls on the truck. One of them was for that and one was for the trany. They never sent me a letter on the recall so I didnt no it had recalls. I dont no what all they are doing but they told me they needed the truck for three days. I hope to pick it up tomorrow and then I will find out everything they did. Wish me luck.
Old Feb 11, 2006 | 09:21 AM
southern pride
Ok got my truck back yesterday. So far so good truck is running great but I havent drove it much. They replaced the snap ring in the trany. Installed ebp sensor and reprogramed pcm ficm and tcm. What ever that means. They say it should help me get better mpg and it shouldnt shut off anymore. Wish me luck.
Old Feb 12, 2006 | 09:42 PM
J.Lauer's Avatar
J.Lauer
Seems like they just keep re-programming and telling the consumer to have at it?
Old Feb 12, 2006 | 10:32 PM
ag-ford-4x4's Avatar
ag-ford-4x4
Its just engineering....theory and practice are rarely the same result. Ford's working out the bugs still.
Rhatler
Apr 13, 2011 01:31 PM
adbscu
Sep 20, 2010 11:40 PM
wburge
Jun 15, 2010 09:35 PM
matty169
Jan 29, 2009 04:35 AM
pafftech
New Member Introductions
Feb 14, 2007 01:19 PM
