86 f150 erratic idle
Old Feb 6, 2006 | 12:28 PM
S.WHITNEY's Avatar
S.WHITNEY
this vehicle has the EEC 4/ efi system. initial problem was fuel pressure regulator letting fuel dump right into intake manifold through vac line, replaced regulator problem solved. now motor wants to idle between 1200 and 1600 rpm in park or neutral way to high for my liking. question, what is correct idle at normal operating temp? and what is possible cause bad egr, evp sensor, solenoid valves, and can any of these be tested individually. thanks. gotta say this is an excellent site with lots of helpful members.
Old Feb 9, 2006 | 12:12 AM
Brothers 4x4's Avatar
Brothers 4x4
I had a 1990 302 (w/eec) that had a similar problem. At a stop light or when idling in the drive-way, it would rev up so high that I though it was going to blow up. I started by pulling vacum lines off and plugging them with my finger. I pulled one of the lines, and when I plugged it, the truck idled right down to normal. I found a tiny pinhole in that line. Replaced the line, and the problem stopped. Hope this helps.
Old Feb 9, 2006 | 09:02 AM
subford's Avatar
subford
Yes it sounds like you have a vacuum leak somewhere.
Old Feb 9, 2006 | 09:39 AM
lmadore's Avatar
lmadore
I would tend to agree. Check the joint between the upper plenum and the intake manifold as well. The upper plenum is aluminum and the intake is cast iron. The metals expand and contract at different rates and this eventually causes the paper gasket to deteriorate. The process is helped along by the fact that this area of the engine experiences some wide temperature swings as the engine warms and cools.
crmiv67
Aug 9, 2013 04:06 PM
bcfordguy
Jan 22, 2008 04:53 PM
MavStallion
Bronco II
Jul 3, 2005 02:35 PM
jommer
Apr 8, 2003 02:49 PM
aerocolorado
Aerostar
16
Dec 23, 2002 02:29 PM
