Fuel pressure question
Old Aug 1, 2013 | 08:04 AM
crmiv67's Avatar
crmiv67
I have an 86 F150 that is idling rough. It used to cut out on me until I replaced the fuel pressure regulator. I have read in other posts that the problem for my rough idle could be leaking injectors. When I replaced the regulator I found a bad injector. My question is that if I check my fuel pressure, with the new regulator, would the only way I would lose pressure be that my injectors are leaking?
Old Aug 1, 2013 | 02:10 PM
projectSHO89's Avatar
projectSHO89
No, you might also have a bad check valve on the fuel pump.
Old Aug 1, 2013 | 04:55 PM
crmiv67's Avatar
crmiv67
Would a bad check valve on my fuel pump cause a rough idle ?
Old Aug 1, 2013 | 06:23 PM
projectSHO89
Not likely.
Have you checked fuel pressure with a gauge?
Checked for fuel in the pressure regulator vacuum line?
Old Aug 1, 2013 | 07:06 PM
crmiv67's Avatar
crmiv67
Yes I have. I am getting a reading around 35. I was having a problem with rough idling and cutting out on me. I replaced the EGR valve, and pressure regulator among other things and thought I had it fixed but after two days of running good it went back to a rough idle. I am going to check my MAP sensor next. Any other ideas?
Thanks
Old Aug 9, 2013 | 04:06 PM
crmiv67's Avatar
crmiv67
I checked my fuel pressure when the motor was hot which is when I have the problem. I have 30 psi at the rail. When I rev the motor the pressure starts to drop slightly and when I let off it drops to 28 and then goes back to 30 psi. When I shut the motor off the pressure increases to 39. My thoughts are that is the reason that when I restart the motor, even after shutting it off when it was running rough, it starts up and runs fine for a while. Does that sound crazy or am I correct in my thinking? Is my next step to replace the fuel pumps? I can hear the exterior pump run when I turn the key. Should I replace that one too on the assumption it is starting to wear out?
Thank you ProjectSHO89 for the suggestion. Without checking the pressure again I would still be searching.
Hey351
Sep 22, 2017 07:56 PM
feo_nuts
Mar 18, 2014 09:26 PM
Matts85
Apr 25, 2010 01:01 PM
BLUEOVAL1992
Jan 17, 2010 01:40 PM
cougardude70
Oct 10, 2003 11:40 PM
