Carb too big?
Old Feb 4, 2006 | 10:36 PM
78fordranger's Avatar
78fordranger
Carb too big?
I have a 750 edelbrock carb and was wondering how much would it effect my stock 400? I was told it would make the truck run rich
Old Feb 4, 2006 | 10:50 PM
grclark351's Avatar
grclark351
i love hearing this stuff! you can tune the EB 750 to run lean if you want to. the characteristic of a carb being too big is that driveability will suffer from off idle and no amount of tuning will help it. are you planning on changing the intake to install the carb?
Old Feb 4, 2006 | 10:54 PM
78fordranger
I plan on buying the preformer intake and cam. I want a little more power but dont want to sacifice drivablity
Old Feb 4, 2006 | 11:04 PM
grclark351's Avatar
grclark351
the EB carbs don't relate directly CFM-wise to holleys. EB's are considered more of a "daily driver" carb, they're more sensitive to low end throttle response. i don't think an EB 750 is going to ruin your day at all, even a holley 750 vacuum would be on the big side but still OK. BTW, there are much better cams than the EB stick. most say it's a dog.
Old Feb 4, 2006 | 11:07 PM
78fordranger
I have a 390 punched 60 over with race heads and a 850 double pumer sitting on top Its old now but its a little much I thiink for a daily driver also what would be a good intake and cam combo? the 400 would be fairly stock dont know if I will punch it 30 over or just freshen it up with rings
Old Feb 4, 2006 | 11:30 PM
Brian S's Avatar
Brian S
Whoever told you got it backwards. Large CFM carbs run lean because there is a lower vacuum signal in the venturi but that doesn't prevent you from tuning.
Carbs: How Big Is Too Big?
http://carcraft.com/techarticles/56919/
Old Feb 4, 2006 | 11:50 PM
53fatfndr's Avatar
53fatfndr
My only suggestion would be to rethink your cam choice. I've heard of too many people that just aren't really happy with the Edelbrock cam. The favorite around here seems to be the Comp Cams 255 or 265 grind cams.
Old Feb 5, 2006 | 01:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
For better driveability try an Edelbrock 600 CFM carb. A stock or even mild build 400 does not need to rev to 6000+ RPM to operate so go smaller on the carb for better fuel mileage and driveability.
Old Feb 6, 2006 | 01:36 PM
tastyklair's Avatar
tastyklair
What they said. Use the 600 Edelbrock and either the Comp dual energy or Crane powermax cam. Check their description to make sure you fall into the right compression ratio for the cam you choose.
Old Feb 6, 2006 | 08:43 PM
danlee's Avatar
danlee
Before selecting a cam. ask yourself 'What do I plan to use the vehicle for?'
If you are looking for lots of torque at low RPM, select a short duration cam with reasonable lift. A Comp Cams 255DEH or XE256 will work well with stock compression. If you want power at highway speeds for towing, a Comp Cams 265DEH or XE262 is better, but you should boost the CR over stock by going to flattop pistons.
An Edelbrock #1406, Performer Intake, and headers will finish it off.
bigfoot7180
Nov 26, 2012 12:53 PM
rangergirl94
Feb 29, 2012 10:05 PM
72tank
Jun 21, 2006 11:59 AM
sped01
Oct 27, 2002 06:50 PM
moocow7777
1978 - 1996 Big Bronco
Apr 8, 2002 01:51 PM
