cab swap 73-79
Old Feb 4, 2006 | 09:44 PM
fastford456's Avatar
fastford456
cab swap 73-79
been a while... anyhow on my 78 shortbox 4X4, I am thinking about taking a cab from a 75 F-250 2 wheel, for the A/C and general body fixes...
anyhow is this possible or not a good idea...??? thanks...fastford456
Old Feb 4, 2006 | 09:47 PM
teds74ford's Avatar
teds74ford
Sure it is possible. They aren't that hard to pull. Only 4 bolts- and a lot of wires, and some linkages. I think mine took about an hour and a half. If you practice on the one you want to get rid of, then you can get it right on the good one.
Old Feb 4, 2006 | 09:49 PM
fastford456
great just what I wanted to hear... I will swap out the transmission hump...etc...
what happens to the body tags registration???
Old Feb 5, 2006 | 08:39 AM
teds74ford's Avatar
teds74ford
That's between you and your state. I suppose you could view it as a "repair" and thereby keep your current vin tag. It is still an F150 underneath it all.
Old Feb 27, 2006 | 08:41 PM
jkm4874ford's Avatar
jkm4874ford
Swapped my 74 cab for a 79 cab a few years back. All after a hit and run. the biggest problem is lifting the cab. First pick it up and hold it in position(lots of friends, empty cab, reduce all weight possible.) Roll frame out and roll new under. If you don't have much help be careful the cab does not balance well. The worst of this job is the akwardness of weight and balance. Good luck.
FAST-FORD
Dec 3, 2006 08:33 PM
fastford59
North Carolina Chapter
63
Feb 1, 2006 07:33 PM
fastford456
Feb 8, 2003 10:15 AM
fastford456
Jan 30, 2003 09:41 PM
fastford456
Dec 26, 2002 11:17 PM
