Sponsored by: Real Truck
Auto Scanner
Old Feb 4, 2006 | 09:37 PM
Rackpatrol's Avatar
Rackpatrol
Auto Scanner
I am going to buy a scanner, BUT I can't decide which one to get. I would like to be able to use it on a (92 - F250), (93 - F250), (2005 - Super Duty) all gas and a (2000 excursion with 7.3 powerstroke Diesel ) I have heard that I wont be able to use it on the diesel engine but maybe it would be able to read the ABS system on all four trucks, is this possible. Also will it be able to tell me which COP (coil on plug) is not working properly. which one would you buy. Thanks for reading this and Please advise
Old Feb 4, 2006 | 09:47 PM
LindenBruce's Avatar
LindenBruce
Rackpatrol,
I bought an Autoxray Ez-Scan 5000 and it works great. It does ODB I and II. You can check them out on the web for details on ABS. Snap-On also has a new scanner called the Micro. I have not played with one yet but my employer's shop has one and the mechanic lives the little thing. Both are about the same price. You can also get some great deals on E-Bay. LindenBruce
Old Feb 4, 2006 | 10:47 PM
BobbyDiesel71's Avatar
BobbyDiesel71
OBDII is only on vehicles(all foreign and domestic) after 1996
OBDI is from like from the mid 1980's trough 1995
Many code readers will read both with adaptors
some kits are inexpensive and may cost more with accessories
You can get free use from AutoZone
Old Feb 5, 2006 | 12:29 AM
biz4two's Avatar
biz4two
Addressing your COP question. The OBDII will be able to read the individual COP if it is throwing a code. Sometimes they do not. No luck with the OBDI. That is where a Coil Diagnosis tool comes in. Waekon’s Coil On Plug Ignition Quick Probe (WAE76560). Just one of many good tools out there.
Check this link:
http://www.aa1car.com/library/2004/us20406.htm
biz
Old Feb 5, 2006 | 04:11 PM
Rackpatrol's Avatar
Rackpatrol
but will i be able to check my abs on both the diesel and gas trucks
Old Feb 8, 2006 | 08:20 PM
Rackpatrol's Avatar
Rackpatrol
OK I have been told to look into the OTC Nemisys has any one heard of this unit Please respond
Old Feb 9, 2006 | 12:20 AM
biz4two's Avatar
biz4two
I've heard of it...and this is one of the "kings" of scanners. The price shows it too.
Old Feb 9, 2006 | 12:41 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
The diesel is your only problem...for the engine components, the computer communicates with a different singal to the scanner. Its an OBDII port but they wont communicate with each other, but i belive i was told when i bought my PC scan software that the abs will work weather or not its a gas/diesel.
Old Feb 9, 2006 | 01:27 AM
biz4two's Avatar
biz4two
Arrow Gas and Diesel
I should have mentioned...YES...will work with both gas and diesel engines.
biz
Old Feb 9, 2006 | 07:45 PM
Rackpatrol's Avatar
Rackpatrol
Thanks, I am waiting for more info from there TECH. support. If it is worth repeating, then I will Post it for the rest of you. Any further input will be welcome
Old Feb 9, 2006 | 11:02 PM
kb8pgc's Avatar
kb8pgc
Will the Diablo read other trucks than the one its programmed on? What if you buy it for the realtime scanner and don't program with it, will it read then?
Dino195
1997 - 2003 F150
Jul 31, 2012 10:18 AM
aquaman
6.4L Power Stroke Diesel
Jan 8, 2012 09:47 AM
bryanlindborg600
Jul 8, 2011 09:54 AM
barttalk
Jun 2, 2010 05:06 AM
Jonest38
Oct 4, 2009 04:13 PM
