Can't get MBRP Dn pipe in, Help
Old Feb 4, 2006 | 12:49 PM
sgrol's Avatar
sgrol
I have turned and forced and cussed the 4" MBRP downpipe and can't get it in. Instructions are useless. I am going in from below and the auto trans dip stick is in the way. If I remove it to get the dp in I won't have room to reinstall it. What am I doing wrong?
Old Feb 4, 2006 | 12:53 PM
bilder12's Avatar
bilder12
I dont know if there is a different dipstick tube for the install of that downpipe. That might be the problem. I know things get pretty tight when the 4" pipe is installed.
Old Feb 4, 2006 | 12:57 PM
bilder12's Avatar
bilder12
hey sgrol,,, scan thru the forum and look at the sawzall reply. they had the same problem and fixed it.
Old Feb 4, 2006 | 01:13 PM
jtharvey's Avatar
jtharvey
I think you should be able to gently bend the dipstick tube enough to get the DP in. I didn't have to bend mine, but I didn't have the MBRP system either. My instructions did say that I might havet to bend it though.
Old Feb 4, 2006 | 01:22 PM
mech2161's Avatar
mech2161
I have heard of removing cab mount bolts and jacking the cab up for clearance.
Old Feb 4, 2006 | 02:16 PM
Muktown's Avatar
Muktown
my mbrp was easy to put in i just rotated the dp until the curve on the bottom was facing forweard and once i got it past the tube i was able to rotate it back. it is easier with 2 people
Old Feb 4, 2006 | 02:23 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
something is wrong with your dipstick tube. the tube should be at least 1/2'' away from the 4'' downpipe. make sure it is the first piece you are putting on in the system, and i used a bungee cord between the framerails to hold the downpipe up far enough to the point where i could climb up top quick and secure it.
Old Feb 4, 2006 | 03:04 PM
sgrol's Avatar
sgrol
Appreciate the replys. I finally got it. Had to hold it up with a jack from underneath and climb on top and pull while moving the dipstick pipe around. Would have been a lot easier with two but my helper went to college.
Old Feb 4, 2006 | 03:08 PM
Kwikkordead's Avatar
Kwikkordead
Oh good you got it in. I had to remove my rear crossmember and jack the transmission up against the bottom of the cab to get mine in.
Hossfly05
Feb 3, 2015 11:29 PM
Simoncx
Dec 3, 2008 08:11 AM
VR6Nutt
May 27, 2008 11:27 AM
akula22
Aug 7, 2007 10:29 PM
