Camshaft & Head Help
Old Jul 1, 2001 | 09:55 AM
canuck's Avatar
canuck
Hello.
I am building a 302 Tow motor for my truck and I have a question for your persual.
Has anybody used the Isky 256/262 Hydraulic camshaft in a tow application?
Would putting a set of 1969 351W head on would be benefical?
302 0.030" over
9.0 to 1 compression
256/262 Advertised Duration
.445"/.450" Lift
110 degrees Duration
Intake Performer RPM(Because I already have it!)
Thanks for your help!
Terry
Old Jul 1, 2001 | 12:27 PM
ummduh's Avatar
ummduh
Man, that seems like alot of cam for a 302, especially in a tow application. I know I'm no expert, but I had a 272degree in a 400 and it was way too much. Your cam isn't too much smaller and has alot less motor to work with..
Want your best bet? Call Isky and ask them what you should run, they have experts on this sorta stuff there to help.. So does Comp cams, and the others.. Hell you could even call summit, they're trained to help..
Anyways, why are you using a 302 as a tow engine? What kind of truck? Stick or auto? 302's in full size trucks usually aren't the best choice..
Matt
Old Jul 1, 2001 | 12:28 PM
ummduh's Avatar
ummduh
Oh yea, the 351 heads are a good choice, you can never go wrong with better breathing.
Old Jul 1, 2001 | 05:11 PM
Southwest's Avatar
Southwest
Make sure you check on the combustion chamber volume on the heads and find out what the compression ratio would be with the pistons you are using. If the chamber is bigger than the heads that came off and you use the same pistons you will lower your compression ratio. I made this mistake years ago but have learned alot since then.
Old Jul 1, 2001 | 07:14 PM
canuck's Avatar
canuck
Thanks for your suggestions!
My Camshafts duration at .050 is 202I/208E. Not that radical as you might think.
Why I am going to a 302 for a tow motor? 90% of my driving is highway and 10% towing. Gas in Canada is $3.50 per gallon. Finally, the motor short block has been already built so...
Finally, it is not a small block chev!
Terry
Old Jul 2, 2001 | 05:19 PM
tetraruby's Avatar
tetraruby
Ah..., give some credit to long stroke length. You want a gas efficient truck, that can tow once in a while? How bout' a 300-6. It'll out pull that 302 and save you some gas $$.
Old Jul 3, 2001 | 11:37 AM
BigBrownTruck's Avatar
BigBrownTruck
Whats your budget? Have you considered converting to Roller Cam like the modern 5.0's? I know that the cams are alot more expensive and the lifters are too. Ford makes a torque cam (roller tappet)for use in the Explorers/Mountaineers.
BBT
Old Jul 3, 2001 | 01:02 PM
beartracks's Avatar
beartracks
NIdude
Apr 14, 2015 10:25 PM
Boss50
Mar 17, 2013 09:51 PM
austinramsay
Sep 28, 2011 06:17 PM
fastwrx05
Oct 1, 2007 11:17 PM
broncman
May 20, 2006 02:15 PM
