Transfer Case Fluid
Old Feb 3, 2006 | 10:13 PM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by guzzle92
I'm getting ready to change mine out. I'm going with Redline D4 ATF. Less than $10/qt delivered to my door.
If you haven't ordered already give some consideration to Redline MTL for the transfer case. It's thin enough to be used in transmissions that call for ATF, but with a little tougher protection.
Old Feb 3, 2006 | 10:31 PM
guzzle92's Avatar
guzzle92
Thanks Kwik but it's on order. I'll take a closer look at the MTL next time. This transfer case hasn't got much of a workout so far so I think the D4 will still be better than the factory stuff that's still in it.
Old Feb 3, 2006 | 10:39 PM
Kwikkordead
The D4 will do just fine. Don't forget to check for little plastic chunks coming out of the drain hole.
https://www.ford-trucks.com/forums/s...d.php?t=393461
Old Feb 4, 2006 | 02:12 AM
wlihntr's Avatar
wlihntr
Originally Posted by PSNut
Well that's interesting! Ford spec's a fluid that won't stand the test of time and usage which could lead to failure at their expense to repair.Hmmmmm...WTF.
you know what dude... put strawberry jelly in the thing. someone asked for reccomendations, so we gave them, and you just try to shoot them down......................
Old Feb 4, 2006 | 06:05 AM
PSNut's Avatar
PSNut
Hey Dude....relax.....just wondering why u recommended the syn over what Ford
specs. Let's be alittle more civilized here. The Ford manual specifies Mercon.
Nut
Old Feb 4, 2006 | 10:13 AM
chapguy's Avatar
chapguy
Is that Smuckers strawberry jelly or can I use synthetic marmalade? I got a good deal on some at the clearance rack. Just curious. .....and of course, just kidding!
Old Feb 4, 2006 | 01:54 PM
stockernavstar's Avatar
stockernavstar
jellys are a whoile different animal, i recomend goober.
Old Feb 4, 2006 | 10:33 PM
dsldrvr's Avatar
dsldrvr
Mercon can be found in Syn variety.
Old Jun 17, 2006 | 02:37 PM
Fraalan's Avatar
Fraalan
I scored some redline MTL but it seems like it may have been sittin on the shelf for a while. Do they have a shelf life?
kawika
49
Jun 23, 2021 11:47 PM
Syncrowave
30
Sep 28, 2017 08:33 PM
Skauber
18
Apr 2, 2017 07:45 AM
Redranger03
1983 - 2012 Ranger & B-Series
Oct 1, 2009 03:48 PM
aurgathor
Oil & Lubrication
Jan 16, 2005 12:50 PM
