Offroad & 4x4
Steering box ?
Old Feb 3, 2006 | 12:25 PM
highboy390fe's Avatar
highboy390fe
Steering box ?
I am in the process of putting on crossover on my 73 highboy i was wondering if there is a difference between having a box mounted on the inside of the frame versus outside of the frame. The reason I am wondering this is because it would be easier for me to have one mount on the outside because i have a bend in the top of the frame on the inside of it. Is it possible or do i have to box the frame and mount it inside.
Old Feb 3, 2006 | 01:17 PM
highboy390fe
This is what i am looking at doing. Will it work the same way as mounting it on the inside of the frame.
http://73-79fordtrucks.com/gearbox1504wd.jpg
Old Feb 3, 2006 | 01:25 PM
proeliator's Avatar
proeliator
Thats not common, nor my preference, but as long as all your geometry is correct, then sure.
Old Feb 3, 2006 | 02:47 PM
ivanribic's Avatar
ivanribic
Be sure if you do mount it there that you plate the frame to reinforce it. It's very common to see cracked frames from these steering box conversions.
Old Feb 3, 2006 | 03:33 PM
highboy390fe
By plating the frame do you mean put a plate on the inside of the ] or to box the frame in
Old Feb 3, 2006 | 03:55 PM
go_racing84's Avatar
go_racing84
Put the plate to the inside of the C channel and use some grade-8 flat washers. Without a plate, if you're running tires that are bigger than stock, and/or you wheel it much, you'll eventually pull the nuts right on through the holes in the frame.
When I changed the steering box on my '72 this past Summer, I found 2 of the 3 bolts were bent and only finger tight because the frame had been so messed up.
Old Feb 3, 2006 | 04:06 PM
highboy390fe
i will be running 16 inches of lift with 44 inch boggers. so yes i would like it to not break.
Old Feb 3, 2006 | 04:35 PM
proeliator's Avatar
proeliator
Wheres the fun in that!?
Yea, like they mentioned, you really should box the frame there.
Old Feb 6, 2006 | 07:50 AM
highboy390fe
I have both steering boxes so i will give it a try if I dont like i'll change it.
Highboy74
Mar 19, 2020 09:43 AM
Zazoos
Feb 2, 2015 11:51 PM
Highboy Honk
Sep 26, 2014 09:02 PM
BigCountry77
May 11, 2011 10:51 PM
bocephus_3349
Jan 17, 2004 08:01 AM
