Bronco II Ford Bronco II
found new b2 for 150 need help
Old Feb 2, 2006 | 09:17 PM
Monty06's Avatar
Monty06
Question found new b2 for 150 need help
i have found a 88 b2 4x4 open 7.5 3.73 auto
so far i changed plugs and got fresh battery.
i even sprayed starting fluid in intake and it acts like it wants to start just cranks i can't pull codes since they cut off the lines. last time they worked on it
they told the owner injectors were not firing i have fuel pressure from valve.
i can hear pump. it has been sitting for 6months without touching. until today bought it for 150.00
any ideas
Old Feb 3, 2006 | 06:24 PM
Ken00's Avatar
Ken00
Even without the connector you can pull the codes if the wires are there and you have the wiring diagram.
A noid light will tel you if the injectors are getting power to fire.
Old Feb 3, 2006 | 11:27 PM
Monty06's Avatar
Monty06
didn't know that thanks ken.
doing oil change too while i'm at it
DallasFan76
Modular V8 (4.6L, 5.4L)
Jun 18, 2022 08:47 PM
daisyq31
Escape & Escape Hybrid
May 8, 2013 10:25 AM
jamesgoodhue
2004 - 2008 F150
20
Apr 10, 2009 12:55 PM
dniccoli
Sep 3, 2008 02:29 PM
littleroc
1983 - 2012 Ranger & B-Series
Dec 11, 2007 08:37 PM
