Plow Mounts
Old Feb 2, 2006 | 08:42 AM
denangme's Avatar
denangme
Plow Mounts
Hey guys, lately I've been thinking about putting a plow on my '86 f-250. Since I'm a workin' man, I've been hoping to get lucky finding a used set-up. The only problem I've encountered so far is that most of the plows I found don't include the frame mount. Anybody know from what year to what year is would fit my truck?? I've been looking at western, meyers, and fisher plows. So any info on these mounts would be a big help.
Thanks,
Bill
Old Feb 2, 2006 | 10:29 AM
Zane M's Avatar
Zane M
I can only comment on Western(the brand we run), and you should be fine with an 80-86(Other years could possibly work, I'm just going specifically on what our Western Dealer showed us). It also has to be for an F250(F350 may work). A plow mount for a 150 can work with fabrication. We had this done on a spare 250 we have when the 150 it was on was retired from the fleet.
Old Feb 2, 2006 | 07:17 PM
84deisel's Avatar
84deisel
here sometimes
80-96 f250-350 western unimounts will work but depending on the year you may have to drill new holes in frame .
Old Feb 5, 2006 | 08:16 AM
denangme's Avatar
denangme
Ok, thanks guys. I've been looking at them on e-bay, but have been a little leary on bidding, 'cause I wasn't sure of the fit. Western was also my first choice.
Old Aug 19, 2007 | 07:51 PM
BrianKosh's Avatar
BrianKosh
Does anyone know if Fisher Minute Mount 2 mounts from an 2004 F350 PSD will fit on a 2002 F250 PSD? Please reply!!! Thanks.
Old Oct 13, 2015 | 07:18 AM
dtgl90vt's Avatar
dtgl90vt
***Old Thread Revival Alert***
Hey just pumping some life into this oldie, rather than start another, I can't find much for Minute Mount plow info for 80-86's. I want to buy a used plow but not sure what to look for in a donor. I heard the frame is the same up to 91 so maybe it wont be a problem if I look from 87-91?
Thanks Again,
Devin
Old Oct 13, 2015 | 12:22 PM
82F100SWB's Avatar
82F100SWB
Yes, 87-91 is the same, the only thing different is bumper mounting itself. I haven't seen a Fisher plow in a LONG time, but it was the plow to have back when I lived on the east coast... Looks like they even discontinued mounts for the 92-96/7 trucks, so, if you do find one, make sure everything is useable.
Old Oct 13, 2015 | 12:52 PM
dtgl90vt's Avatar
dtgl90vt
Really? I though fisher was the lead plow company
Old Oct 13, 2015 | 12:56 PM
dtgl90vt's Avatar
dtgl90vt
Sorry, this will be my first voyage into the plowing world, doesn't a minute mount only at the push plate off the frame? not the bumper?
Devin
Old Oct 13, 2015 | 07:31 PM
82F100SWB's Avatar
82F100SWB
Plows are very regional, and Fisher has always been very popular in the northeast, and in the Canadian maritimes(I'm from Cape Breton.)
In my local area, Boss, Western and Arctic are the common ones, with an occasional Meyer(closest dealer is 3.5 hours away) and Blizzard.
As for the bumper attachment, with some plow bracket setups, the bumper ends up bolted to or through the push frame itself.
Old Oct 15, 2015 | 05:15 AM
dtgl90vt's Avatar
dtgl90vt
Just for the record, I think fisher part number 7132 is the correct push plate for the 80-86 trucks as well. http://library.fisherplows.com/fisherplows/pdffiles/6485.03_050106.pdf
If I ever verify this I will make sure to post back my findings
Devin
Old Oct 15, 2015 | 04:59 PM
Diesel_Brad's Avatar
Diesel_Brad
Just to clarify. 80-91 frames will bolt on. (slightly different bumper mounts on the 87-91)
A 92+ frame will NOT.
The biggest problem with the older plow setups for the truck is they are hard mount. And by that I mean when you take the plow off in the summer season, you still have all the lights pump and mount still on the truck. I guess it doesnt bother some, but for me it is a nuisance to clean around and work around. Also when you go to put the plow on the truck for each storm, you end up laying on the ground to hook the two lower pins. Not my idea of a good time.
if you are handy, look for a "quick attach" setup and modify it to your truck. Western callers their Uni-mount(earlier style) and Ultra Mount(current style) Fisher had the minute mount 1 and 2.
I have yet to see any quick attach setup my meyers
Old Dec 6, 2015 | 04:08 PM
Charles lakins's Avatar
Charles lakins
I moved the post to here ....https://www.ford-trucks.com/forums/7...questions.html
couldn't figure how to start my own thread
Old Dec 6, 2015 | 07:38 PM
Diesel_Brad
Originally Posted by Charles lakins
I decided to use an older arctic that was on an early pre 90 bronco and modify the frame to fit my 97 truck, today we finally have the front harness attached and will do the bottom plow mount tomorrow, i plan on mounting the pump behind the front cross section and cutting the middle lower chunk of bumper out for top ups and fit around the top support braces
here's a few pics up til now
Welcome to the forum, you need to post here..
1997 - 2003 F150 - Ford Truck Enthusiasts Forums
Old Dec 6, 2015 | 08:06 PM
Charles lakins
Moved.. Thanks for the welcome too
Corey Lack
Jan 27, 2017 06:04 PM
fordyduty
17
Jan 15, 2017 06:19 PM
meborder
Nov 26, 2016 06:37 PM
Sondre Næss
Jul 19, 2016 09:23 AM
19-F250-78
May 8, 2016 08:02 PM
