undercoating the bed
Old Jul 10, 2001 | 05:01 PM
jwtimme's Avatar
jwtimme
I have the bed off my 72 ford truck. I have cleaned all the rust off and there are no holes in the bottom of the bed. What works good to undercoat the bottom of the bed. Should I spend the money to use truck spray in bed liner or will it be a wast of my money. What have you used and how well has it held up.
justin
Old Jul 10, 2001 | 08:02 PM
otto's Avatar
otto
I think I'm going to use "rubberized undercoating" in an aerosol can, im going to use it on the frame with paint over it and just the undercoating on the underside of bed and cab
Old Jul 10, 2001 | 09:12 PM
RubberDuck's Avatar
RubberDuck
Otto is right, 3M makes a rubberized coating that comes in an spray can. It works not only as a protector but a deadner. It's not as tough as say rhino liner, but it will get the job done. I've used it on floor boards, works wonderful. Any parts store should have it.
RubberDuck
Old Jul 11, 2001 | 04:26 AM
karljay's Avatar
karljay
I'd do something before the undercoating. I'd use some form of rust treatment. I'm using Por15 on mine, but if you have all the rust off and it's completely clean, you can use a good epoxy primer. The cost is about the same, and the Por15 is an excellent choice.
I'd calculate the cost of the rubber undercoating and compare that to the Herculiner. I got my Herculiner for $75 and the undercoating was about $3.99 a can (and a lot easier to apply)
By the way, the Por15 goes on directly over rust, so you just need to wire brush and clean with acetone and it cost about $30/qt.
Old Jul 11, 2001 | 05:17 AM
jdbanks's Avatar
jdbanks
Por15 goes OVER the rust? What exactly does it do? Does anyone have a link where I can learn more about this?
*jdbanks*
Old Jul 11, 2001 | 09:53 AM
buzzard's Avatar
buzzard
jdbanks, try www.por15.com
Old Jul 11, 2001 | 10:00 AM
beartracks's Avatar
beartracks
If you had a compressor you could use a 3M body shutz gun and can of undercoat. Works really well and isn't too expensive. Other wise I have had good results with the rattle cans.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jul 11, 2001 | 10:05 AM
jjones's Avatar
jjones
If the bed is off and laying bottom up, I've always used roof coating (Black Mammy) with good results. Of course I'd recommend putting on a good coat of primer first. Rubberized roof coating from a gallon can goes on best with a good thick brush. Cheap and effective. Be sure to wear desposable gloves and long sleeves or it takes 4 days to wear off.
Just my 2 cent.
Jeremy
74 Bronco (modified out yeng-yang) - 302
75 F150 Custom 4x4 - 360 stock
76 F100 Ranger - 302 stock
Old Jul 11, 2001 | 10:47 AM
FE427TP's Avatar
FE427TP
cowmilker08
1983 - 2012 Ranger & B-Series
Nov 6, 2015 11:37 PM
ajbremer
Mar 24, 2015 01:39 PM
DougJ_1997PSD
Feb 5, 2015 12:29 PM
1974f350
Ford Truck Parts for Sale
Dec 9, 2014 10:05 AM
Mikemusial
Sep 27, 2014 10:21 PM
